Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Lg LDF6810ST dishwasher not cleaning top rack
The top rack is always dirty.  There is also detergent left in the door cup after washing.  It seems like it is not spraying from the top arms.  I figured this is a pump issue.  The pump is run from a brushless stepper motor so I am guessing one of two items are at fault.  Either the motor is bad, so why would it turn, or the control board that controls the speed of the motor/pump water pressure is not telling to motor to spin at the correct speed.  Any ideas for testing either item?
  • 3 more comments
  • Anonymous Oct 04, 2008
    I have the same problem. The issue was already fixed once about a month ago, but reappeared. Diverter motor is most likely bad or stuck. When removed and attached to a power source, it appeared to function properly.
  • hoopersir Nov 15, 2008
    same exact problem. Soap still left in dispenser. Dishes dirty. Seems like the arms are not spinning , but how do I test? I have aligned the arms, and they are not in the same place when I open the door, but it seems like falling water or vibration that moves them, because food particles are still on dishes.
  • silverdolls Feb 05, 2009
    I, too, have that problem--soap left in the dispenser (even after using less detergent), dirty dishes on the top rack plus an oder is developing in the empty stainless steel dishwasher.
    Kate
  • Anonymous Feb 14, 2009
    Just bought the new LZg and have same issue.
    Seems like there is not enough pressure to turn the water bars.
    Not happy with this unit thus far
  • Anonymous Apr 05, 2009
    Same problem... so disappointed as it worked great for the first few months but now the bottom sprayers barely rotate and have very little water pressure which, in turn, leaves the upper arms dry and still. Smell continues even after running empty... cleaned out ALL of the arms -- not the problem... seems to be a "pressure" problem within the unit.... will try Oct '08 and March 22, 2009 suggestions... ugggggghhhh... thanks.
  • 423 Answers
Almost all of the problems mentioned above will be solved by having the owner buy a name brand detergent powder (like Electrosol or Cascade) and using a little less than you think you should.
For those who continue to have problems with poor cleaning, you need to remove the lower spray arm (pull straight up firmly, then out) and then remove the 9 screws that hold the filter in. Using a flashlight, inspect everywhere in the sump area (be careful of broken glass!) Remove all debris and especially look for something blocking the white check valve that is driven by the Vario motor to control the alternation between the upper sprayer arms and the lower arm. Reasemble and test.
If inside dishwasher is a mess with white mineral deposits, recommend you place a bowl filled with white vinegar on the rack of your empty DW. Start a quick cycle with no detergent added.
Check out how clean it is when you are done!
If you have problems after this, please post back what you are seeing.
Good Luck!
Posted on Apr 08, 2009
There is a cicrular plastic part behind the pump vanes that directs water flow by rotating to one direction or the other. If it doesn't turn correctly the upper spray arms do not get water. Place 4 cups in each corner of the upper rack and start the cycle. If you hear the motor running but the cups do not fill that is the probable problem. You must disassemble the pump housing to get to the part. I think water flow turns the part but I'm not sure. I jut rotated it back and forth reassembled the pump housing and worked fine -no more soap left now that spray is getting to it.
Posted on Mar 22, 2009
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
When I put detergent in dishwasher and turn it on, it seems to go through the cycles, but when it stops, the detergent is still in the detergent bin and the dishes are not clean.
Assuming the detergent dispenser door does open, it is likely the water is not reaching the top arms. Put a cup in normal position on the top rack and see if there is any water in it at the end of the cycle.
Likely causes are blocked arms or water distributor or the wash impeller is not working in the pump. The dishwasher uses the same pump motor for wash and drain cycles. You can check this by hearing if the water is getting swashed around when the wash cycle is on.
Check the impeller and water feed as shown in this diagram.
Hope this helps.
Jan 19, 2011 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwasher does not clean the dishes, it lso leaks out of the lower left side of the door. I know this is suppose to be a quiet dishwasher but it doesn't sound like it is spraying any water. when i do open...
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Jan 10, 2011 | LG LDF6810ST Stainless Steel Built-in...
After the dishwasher runs there is a lot of soap left in the soap dispenser. I've tried powder and liquid. Liquid is a bit better. I've tried using less soap but there still is a lot left. Also my glasses...
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
May 21, 2010 | LG LDF6810ST Stainless Steel Built-in...
The dishes are not getting clean on the lower rack even after several washes. What can be done?? The top rack comes out clean. It almost seems that the water flow on the lower rack is limited. Something as...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | LG LDF6810ST Stainless Steel Built-in...
There is always detergent left in the compartment and my dishes don't seem clean. It doesn't seem to matter if I use powder or gel detergent and I don't overfill it.
I expect your filter is clogged which does not allow sufficient water to get from the pump to your spray arms. Thus they do not clean out the detergent nor do they clean the dishes. You might test this by placing a glass right side up in the top rack and run a normal wash cycle. The glass should fill at least half way with water.
Mar 15, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Dirty racks
What is the manufacturer and model number of the dishwasher?
Here is the process I would follow to remove the gunk.
Start a short cycle in the dishwasher, without adding detergent powder and after the (hot) water has filled the DW and the wash cycle has begun, open the DW door and add 1/4 cup of household bleach. When the water drains and begins to refill for the 2nd wash cycle, check the dishwasher to see if anything has gotten better and if not, add another 1/4 cup of bleach as soon as the hot water has refilled. Allow the DW to finish the full cycle.
Begin another short wash and as soon as the initial hot water fills and the wash cycle begins, open and add 2 cups (approximatly) of white vinegar. Allow the whole set of cycles to finish and check the insides.
If grease remains, I would use a de-greasing spray (avilable at all hardware stores and most food stores.) Spray on and use paper towels on all surfaces.
Because I do not know the make and model # for your dishwasher, I can not give you a part number for replacement racks.
Good Luck!
Apr 05, 2009 | Dishwashers
Doesnt dry dishes, top rack not clean, has been serviced 3 times
If you have checked everything that was mentioned (and none of them are the issue) then either the heater inside the unit is not coming on during the wash and rinse cycles and/or the fan motor inside the door is not coming on during the dry cycle. A technician can easily check this out with the correct tools and by putting the unit into test mode.
As for the top rack dishes being dirty and there being soap left in the dispenser, this sounds like wash motor is either weak or the vario motor is not switching between the upper and lower spray nozzles. The sump assembly should be replaced for this issue.
Jan 18, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
May 26, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
1,301 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
