Question about Konica Minolta magicolor 2400 Laser Printer
Paper jam, no printing, constant error
My printer was working fine until it ran out of paper. I replaced it with the exact same paper, and then it jammed a few times, then it only partially picked up the paper, and now it has a constant error message and won't print anything
  • don94403 Oct 03, 2008
    Pretty much the same symptoms, although I can't say that it occurred when I reloaded paper. I've had several years of excellent service from this printer, but it began producing a paper jam error occasionally, then with increasing frequency and within a week it completely refuses to feed paper. It doesn't even lift the sheet into the rollers. Could it be a scrap of paper torn from an earlier jam, but which I now can't reach? Is there any way to clear it, short of disassembling the entire printer?
  • applewhitem Oct 05, 2008
    I called Konica on this problem and a very helpful rep walked me through it. The problem is the paper feed pickup roller. You have to open the printer, take out the drum roller, and then you'll see a ridged roller at the bottom. This gets some paper dust on it evidently, and it needs to be wiped off with a mild detergent solution and then air blown dry. It worked for me and now my printer is back to normal. The rep also helped me with a setup issue that was preventing me from being able to rotate my toner cartridges. That one was related to the sharing printers option, and was also resolved. I recommend calling Konica directly when you encounter problems. They have helped me several times.
That's an excellent way to show what to do. But I'm afraid it didn't remedy the problem. But thanks, in any case.
Posted on Oct 05, 2008
  • 1,031 Answers
You can Visit the Konica Printer Knowledge base, which explains on a .pdf and with a video, how to clear the basic fuser roller jam with a piece of card.,no printing,etc click the link and put in your product type that wil take to faq page youll see the issue and solution elaborated
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/start
and work your way through the links.hope this helps
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
May 27, 2008 | Office Equipment & Supplies
Paper jams out of the fuser
I had constant jamming problems (mostly with pages with a lot of color coverage) when I was refilling toner cartridges with cheap refill kits off of ebay. Switched back to new brother cartridges and have not had a jam since.
Apr 28, 2008 | Brother MFC-9420CN All-In-One Laser...
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Paper Jam
Double check when u remove the paper it may still have some left
Need to know the exact error
Thanks
Jaywizz
Oct 04, 2007 | HP PSC 1210 All-In-One InkJet Printer
Konica Minolta magicolor 2400 Laser Printer Logo
122 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
