Philips 625 DVD Player showing standby light but won't switch on
Player is sat on standby and won't come on when the power button is pressed. Used it recently and it was fine, just suddenly won't switch on at all. Any ideas?
  • allie_h Oct 02, 2008
    Thanks I'll find someone who can have a look at that for me :)
    Sergeant:
    Champion:
  • 223 Answers
I think there is a fault on your power supply board most probably a faulty diode or voltage regulator but I would check the diodes first. If you are not able to do this find a competant technician. Hope this helps.
Posted on Oct 02, 2008
I have a PHILIPS DVP3962. My DVD player used to play where I left off watching my DVDs, but recently, when I turn it off and turn it back on, it starts from the beginning of the DVD. Dose anybody know why...
Resume function is wiped from the player's memory buffer whenever the unit is switched to standby (either with the [POWER] button on the main unit, the remote or turned off at the wall), the disc is removed, or the [STOP] button is pressed twice (either on the front or via the remote).
(The simplest thing you can try is to insert a DVD, play a few minutes of its main title, press [STOP] once, not twice, leave it for 10 minutes, then press [PLAY] - it should resume, and thus continue your movie from where you left off)
Resume is considered 'temporary memory' in DVD devices, and therefore is not intended to store the playback point of the disc permanently whenever power is lost, [STOP] is pressed twice or discs are ejected.
However, this is relatively normal, and is not a fault, but it can be annoying to the user.
Apr 26, 2011 | Philips DVP3962 DVD Player
I was exploring the setup menu and I found an election of Progressive Scan "on" and "off". When I tried "on" then the picture get out and no image was since then. I can't...
There are 2 ways you can reset the player to default factory settings, although I am not sure about progressive scan being reverted back to interlaced output.
1) Unplug the player (or switch off) at power point, as soon as you reconnect (switch on) power to unit, press and hold the [STANDBY-ON] button (on the front). As soon as you see 'IS TV ON?' on the front panel display, release the [STANDBY-ON] button. This should reset it.
- OR -
2) If you do not have the instruction manual, you can download a free pdf of it;
http://www.retrevo.com/support/Philips-DVDR615-DVD-Players-manual/id/280ag201/t/2/
I hope this helps a tiny bit.
Mar 17, 2011 | Philips DVDR615 DVD Player
Unit on standby mode only, the dvd rack didnt open when open button was pressed.
Turn off and unplug at mains Plug back in and turn on press standby button so power light come son. If pressing open button on player (rather than remote) doesn't work it may be a disk that is not sitting properly in the tray. You could try sliding a very thin blade (preferably something with an insulated handle!) gently in the top of the tray to press the disk downwards whilst gently prising under front edge of the tray with a small screwdriver. If you can manage to press the open button at the same time as doing both these things it may help.
If that fails to solve the problem it may be a broken drive belt or worn cogs in the tray operating mechanism. DVD players are so cheap these days that repair is seldom worth the expense.
Feb 23, 2011 | Philips DVP642 DVD Player
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
My dvd model is philips dvp 3005 and it is in standby mode when i start my player standby led glows and when i press stand by button on the player or power on from remote control the screen shows no disc...
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Sep 05, 2008 | Philips DVP-3005 DVD Player
Philips DVD Player Seems Dead
It looks like this problem has been discussed here: "Standby light blinking."
Mar 24, 2008 | Philips DVP642 DVD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Philips dvd player not working
Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
Jun 05, 2006 | Philips DVP630 DVD Player
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Electro Med Services...
