Question about Brother MFC-5440CN All-In-One InkJet Printer
NO CARTRIDGE IT KEEPS SAYING I HAVE NO CAYNE CARTRIDGE AND THERE IS ONE. I HAVE PUT A NEW ONE IN AND IT STILL SAYS THE SAME THING. SAYS TO OPEN THE TOP AND INSERT A CARTRIDGE.
  • SAGURU Oct 03, 2008
    I ALREADY TRIED THAT BEFORE I POSTED - ANY OTHER SUGGESTIONS
  • Anonymous Feb 19, 2009
    I have the same problem. when i turn it on it says 'change cyan', but it is new already, if i open it and try to put it correctly then it says 'no cartridge', and the same thing happens over again when i turn it off and then on.
  • 4 Answers
TRY THIS FIRST!!!! it is the easiest and works everytime for me. Just unplugg it. I read somewhere, probably here, to do this. Actually pull the power plug out, not just turn off. I also took out the connnection plug to the computer for extra measues. Wait a few minutes then plug everything back in and turn on. It is like a computer rebooting. The printer will reinitalize itself and do a systems check. All the cartridges were recognized and the inkloads were correct. Had the same problem when I change the Black. Unplugged everything, and then perfect. I really like this multi function printer. it is the best for the money, cartridges are individual and cheaper then others. So if I need to just unplug every now and then not a big deal.
oh, I have always only used Brother cartridges, so I do not think it is cartridge problem. Before doing the tape just try this first. Wish I would have known about this solution with my previous one which obviously I threw away and did not have to.
Posted on Oct 03, 2008
I took the same cartridge had it refilled put it back in the printer keeps saying troubleshooting print cartridge what do do
when u put in a refilled cartage the reset will not engage ,so it will always read out of ink, check printer, etc.reset you printer manually everytime u print is the only thing u can do or buy brand new ink.and install new ink then remove this will let u print once,u will have to do this every time try xing out of prompt several times on youre computer if u r printing through it and that will work,but if u r printing on straight printer u half to reset it every time. hope this helps.
Jan 04, 2015 | HP J4680 Office Jet All-In-One Printer
My hp officejet ignore printing after replacing of cayne colour cartridge.
I hope Magenta cartridge is not refilled one right? :#Remove all cartridges and print heads, disconnect power & USB cable, switch off wait for couple of minutes.. give power switch on the machine wait do as per the message appears on display.. once installed cartridges and printer heads wait for the ready mode:.. once ready mode appears attach USB cable then print and see..# check with old and new cartridge see the difference of message.. if both messages are same it might be problem with ISS(Ink supply station) faulty, try it get back to us..for further remedies.
Feb 03, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Display keeps saying check cartridge on the right i check keeps saying it put a new cartridge in still says same thing photosmart 2610
You could be getting this problem if using refilled inkjet cartridge. Try replacing cartridge and see if message clears.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Problem with printer
Have you tried a new magenta cartidge. I think it has run out, that'swhy you can only print black
Mar 23, 2009 | Canon imageRUNNER C3200 Color Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
