Question about RCA F31672ET TV
F31672et rca tv
Picture has a red tint all over and can not adjust color
  • bigdogfranci Oct 03, 2008
    thank you can it be repaired
    Problem Solver:
  • 63 Answers
If this is an older big screen you probably have one of the light bulbs out this happens overtime
Posted on Oct 03, 2008
    Genius:
  • 1,011 Answers
Sir,
You did not say what type of TV you have. A flat screen plasma, LCD or a CRT (older picture tube type)? The fact that you can get a black and white picture just about rules out a problem with the plasma, LCD or picture tube display. The fact that a color picture is only displayed in shades of blue and green points to a lack of red. This can be as simple as adjusting the tint, or can be caused by a defective red video stage, usually the output stage, or a dead color oscillator. In the latter two cases it is a circuit problem and would require repairs. Service on TV sets as you may know is no longer inexpensive. Find the tint adjustment first, the kids may have gotten it way off. Put the bar in the middle, or if you have a reset option which returns all picture settings to the levels set at the factory try that. Good luck
    President:
  • 2,712 Answers
Is this a projection/plasma/CRT?
  • Swilin Sampson
    Swilin Sampson Oct 03, 2008
    You switched something from PAL/NTSC --> RGB or the other way around?
  • Swilin Sampson
    Try a hard reset first..Unplug the TV from the wall socket for about 2 hours and try again. See if you can adjust the tint/color through the menu options as well. If you have tried to correct the color in the menu and had no luck then the problem can be as simple as adjusting the video
    amplifier or the amp could be failing. The only way to know for sure of
    what the problem is will be to have the circuitry checked to find what
    is out of specs. A small shop will often charge less than a large
    repair facility.
    Should you require further clarification,
    never hesitate to ask. It would be my pleasure to clarify my answer to
    your question. If after reviewing the above information, you have
    additional questions, I will be glad to answer them.
    Cheers!
    IrishDruid
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
I was recently given this tv and the picture has a red tint. So much so that it is unwatchable. I have tried adjusting the color and tint but it does not change. Any ideas?
There is a red drive issue going to the picture tube. Being that the problem could be anywhere from the signal processor to the picture tube itself it is hard to say exactly where the problem is. There are a lot of parts between the signal processor and the picture tube. Have a shop check it out for you. Thanks for using fixya.
Dec 14, 2009 | RCA 20F511T TV
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Rca tv screen went all red. you can still see program
Color wheel controls the color. try replacing then reindexing the color wheel. Let me know if you need further assistance.
Mar 14, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Televison & Video Logo
275 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
