Question about Admiral AW22 Top Load Washer
Washing machine, admeral,
Tube bangs , dances all over floor, should i replace belt ?
    Scholar:
  • 116 Answers
Yes go for belt first, cheapest option.
Posted on Nov 09, 2008
Why is my washing machine making a loud banging noise when spinnig?
wip the top off and have a look at the big stabilizer springs that hold the drum up if one is missing or broken off replace it,,,,if these springs brake or fall off the washer dose a grate dance around the floor done it?
Nov 24, 2010 | Indesit W 123 Front Load Washer
Celcus washing machine makes a banging sound when starting on spin and slowing down from spin
It could be caused by loose or damaged bearings or even damaged belt. You might have to replace worn out belt and bearings. Also find out if the washer is sitting on an uneven platform. Make sure the floor is even and the machine is not tilting.
http://www.washingmachineadvisor.com
Nov 22, 2010 | LG WM2077C XL Front Load Stackable Washing...
How do i better support my washing machine to make the floor sturdy
Every washing machine has crew type legs on each corner, if it teaters from corner to corner it is not properly leveled. you need to adjust the legs up and down until the machine is level and does not teater from corner to corner, like rock solid..when you put in a load of lawndry that is lop sided, the machine has a tendency to dance around the floor during the spin cycle, to stop this open the lid and re-adjust the lawndry evenly then close the lid and it should quit dancing around the floor.
Now if your floor is too weak, you need to get under the house and put in somemore beams to support the weight of the machine....
Good luck....
Nov 11, 2010 | Kenmore Washing Machines
Washer skates over the floor in fast spin cycle
they make a bracket to secure the washer to the floor,check with dealer were you got the machine
Jul 05, 2010 | Samsung WF328AA Front Load Washer
My washer is not quite 3 years old and has started a loud banging sound especially when it spins, it sounds like an MRI machine
One of the dampers has gone so the drum is allowed to move too far from its centre when it is spinning and is hitting the outer shell
Once it gets out of whack the machine will dance across the floor if it is allowed to.
You need a man that can
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine dances all over at high speed spin.
Push down on each corner, one at a time, when you push on a corner and the dancing stops, that's the corner that needs balance. adjust the foot.
Jun 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Levelling washing machine indesit iwme
washing machine dances allover the floor when on spin cycle
Mar 13, 2009 | Washing Machines
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Washing Machine Dance
Cars, does the basket lean to one side? There might be a couple of issues. The coupler that seats between the motor and trans could be wollowed out causing vibration. Another is that one of the balance springs came off or broke. I'm going to attach a photo of the springs so you can see what this looks like. You can remove the whole cabinet to check things out or tip the washer back and take a look.
Aug 24, 2006 | Kenmore 23022 Top Load Washer
Admiral AW22 Top Load Washer Logo
77 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
