Question about Jenn-Air JSD2789GES Side by Side Refrigerator
I have a jsd2789ges jenn air water dispenser not working at all
Changed main pcb on disp sill not working push glass light comes on but no noise no water no ice
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
The ice maker will stop the water from flowing on the door or the auger motor from turning?
Posted on Oct 02, 2008
    Sergeant:
  • 409 Answers
sounds like you have an icemaker problem. i would recommend replacing it.
Unit is a Jenn-air JRSD209T. Two problems. When water runs to fill the ice maker it runs down into the ice shoot leaving you with a cup of water with your ice. Second problem. Witnessed a red glow...
For your first problem i need a bit of a clarification. Is what your saying,when you dispense ice through the door some water also comes out of the dispenser??
For the glow that is perfectly normal,what your seeing is the glow of the defrost heater melting off the biult up frost. If it did not come on and melt the frost the refrig would not be cooling.The term"FROST FREE" is a bit misleading. Their is automatic defrost refrigerators such as the one you have, and the manul defrost that you need to defrost manually every month.
Gene
Aug 12, 2011 | Jenn-Air JSD2789GES Side by Side...
Can not shut off water dispenser. Must open door. Then put it in lock position
The best way to find which part of the dispenser control that may be causing the dispenser to remain on is to unplug each part that leads to the dispenser keyboard until found. The service manual for your model JSD2789GES seems to point to the keyboard yet when I look for parts the only part that is shown is the circuit board behind the keypad. It may be part of the replacement circuit board=> 61005274 Dispenser Control Board you can ask these people if the keyboard is availabe and they will be happy to help you. I would normally send the service manual here but Maytage ask me not to do that. You can request the Service Manual through Here Just ask for the JSD2789GES Service Manual and I will be glad to help you and glad to help you get this fixed, Thanks Sea Breeze
Jun 15, 2011 | Jenn-Air JSD2789GES Side by Side...
Unlock water dispenser
ALL MODELS ARE NOT THE SAME BUT MOST JEN AIR 'S ( PUSH THE LOCK BUTTONON DISP PANEL AND HOLD FOR 3 SEC. AND IT SHOULD UN LOCK. N ow if the panel is not working the lock will not . mm
Jul 22, 2010 | Jenn-Air Refrigerators
My ice and water dispenser sticks. I have to open
The door flap may not be opening and closing completely thereby trapping the ice. There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 13, 2010 | Jenn-Air JSD2789GES Side by Side...
Having trouble getting more than just a few drops of water out of the water dispenser.
If you get ice cubes you have water. Check the plastic line from the solenoid valve to the water outlet, be sure it is not frozen. You may have a partially plugged filter in the water line or a bad solenoid valve.
Good Luck
Gilsh
Nov 29, 2009 | Jenn-Air JSD2789GES Side by Side...
Buttons don't work on my ice and water dispenser, can't switch between crush/cube/water. Light also doesn't work. Jenn Air Model JSD2789GES
Most refrigerators have a control board behind those buttons. I'm betting your board is bad, or possibly not getting power. Remove the dispenser cover and see if the board is still clipped in the housing, and that it is plugged in.
Sep 08, 2009 | Refrigerators
I have a Jenn Air JSD2789GES side by side refrigerator and The water won't work to the ice maker or the water in the door?
Check if the water is on.
check if the water filter connected correctly or the bypass.If the filter is new and the appliance is new you should press the water handle or button till the water comes as the selenoid are open during you push.
Jun 30, 2009 | Jenn-Air JSD2789GES Side by Side...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
163 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
