Technika LCD32-407B TV sudden says no DTV Signal. Have also got red screen and operating the remote does nothing. Terrestrial YV works OK. Set is only a few months old, Can you hrlp> Mike Firth
5 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Posted on Jul 03, 2007
  • 301 Answers
SOURCE: Red blotchy picture
try an AV memory reset in the tv menu. each input has different settings for picture options
Posted on Feb 20, 2008
  • 14 Answers
SOURCE: Mintek 26 inch LCD HDTV with built-in-DVD remote not working
The reason you can't pull-up the Mintek website is because the company is out of business. I have one that is frozen on one channel and none of the buttons or remote will work. I took it to a repair shop and the said one of the circuit boards is bad but since the company is out of business they can't get the needed part. The only way to get the part is to find a set which can be cannabalized for the needed parts.
Posted on Mar 06, 2008
  • 13433 Answers
SOURCE: I have a Mintek DTV-265-D.
Mintek - 20839 and 20717 have you tryed these two?
Posted on Jul 05, 2008
  • 668 Answers
SOURCE: TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Posted on Jun 19, 2009
My ws-55311 shows blue screen on all inputs except the DTV input
This set has 3 hidden menus accessed with a different 4 digit number code----You need the Mitsubishi remote to enter.
One of them is the Option menu which will allow a hard reset of the TV back to factory original---98% of the time it will restore all inputs--cures all sorts of odd problems.
If you have that remote and want to try it let me know for sure the model number and I will give you a link to the instructions for doing it.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Video 5 / DTV disply in upper left screen will not go off.
Press Info / Display button on TV remote, on-screen display will disappear.
Sony TV Remote is required for that function, other remote wont work.
Thanks.
May 21, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Dec 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
I installed an Insignia converter box, Model # NS DXA1, and it worked fine. I did not realize it would decrease the size of my screen, so I disconnected it and figured I would try again later. I have...
Ok, you have 2 issues:
1) Consult the manual page 8 for setting the 'type' of TV either 4:3 (Standard) Aspect Ratio or 16:9 (Widescreen) Aspect Ratio. Then the Picture Size for 'each individual station' can be Selected via the button on your remote in the upper right hand corner. It's labeled "ZOOM". As you push the button, it will rotate through the size types available. If you have an older standard TV (4:3) and want to fill the entire screen, then select 'CROPPED' for every channel(my preference). You will only see a center cut of the entire picture and will lose some picture on either side, but most of the action will remain in the center of the screen. If you select "SET BY PROGRAM" then some programs will appear in their actual Aspect Ratio so some will be in 16:9 and some in 4:3. More and more programming will end up being 16:9(the new DTV/HDTV Standard). Set this to your liking.
2) This is going to take a bit of explaining:
Depending where you live geographically, whether in a home or an appartment, and the Type of Antenna you are using, your reception problems may be affected by a combination of these. The FCC was not completely forthcoming in letting the public know that the best way to get DTV signals(and Analog) is with an Outdoor Antenna and that indoor Antennas may be useless. Plus most of the 'fancy HDTV touted" Indoor antennas are various degrees of bad when it comes to VHF reception. The new system they(FCC) selected has lowered significantly the power at which TV stations broadcast. So most people using Indoor Antennas may not get all of their favorite channels even with the best of indoor antennas and doing everything right with the 'placement' of that antenna. The same goes for and Outdoor Antenna. Just because you have a premium outdoor antenna and it has worked perfectly for the last 10yrs.(of more) with Analog TV, DOES NOT MEAN THAT it will work perfect with DTV for a few reasons:
1) DTV Signals, because of their lower power, require very deliberate placement of an antenna. Just pointing it in the right direction is not enough. DTV signal reception is a bit like 'Swiss Cheese' meaning if your are getting poor results and think that rotation will fix it, you may be wrong. If you are in the 'hole' and rotate, you are still in the hole. Sometimes moving your antenna a couple feet laterally can make a huge difference.
Why? Because the direct DTV signals coming from the TV stations are in the Kilowatt range (analog was usually more than a million watts!) They have now become more sensitive to interference from the back and sides of your antenna. Some sources of interference can be a reflection of the same signal off of a nearby tower or building which cancel some of the direct signal resulting in low or no signal. FM Radio transmissions, an Analog TV station from Canada(they don't go digital until 2010) operating on the same channel as your favorite Channel's new channel assignment can inject so much noise that your tuner cannot process it. Remember, runnig through just about every neighborhood are many other Wireless/Microwave Services: Phone, Internet, TV, Paging Systems, etc.. These, too can ave some affect.
So by moving your antenna to a position that I refer to as the "Sweet Spot", you are allowing your antenna to get more of the direct signal and 'de-tune' the unwanted signals from the back and sides.
Why did the channels you found before not show up the next time? Well, based on your current antenna's position and the signal strength its receiving from those stations, the level may have dropped off due to some of the above. Every DTV and Converter Box has a 'lower signal level cut-off point', meaning it needs so much signal before it cuts off. Because DTV either gives you a perfect picture or its gone, the old method of looking at picture quality to make sure your antenna was placed correctly is not valid. So the maker of the Converter Boxes put "Signal Strength Meters" in every box. Get to know where this is. It is your new best friend and is the only way you can be guided when placing your antenna. It can usually be accessed by pressing a button on the remote labeled :"SIGNAL or METER" and sometimes "DISPLAY or INFO". Some Boxes, like many DTV Sets, require you to go into the menu settings to locate this feature. Usually the sinal strength is indicated by a RED, YELLOW & GREEN scale and may have a % indication. To have reliable pictures, you should be above 60% or in the GREEN Zone. If you are only getting less than 60% or Yellow Zone, you may see the picture break-up into little squares or 'Pixelate' as it is known. If you are in the RED Zone or less than 30% your Box or DTV will not lock and give a "NO or LOW" signal indication. It is normal to see the meter indication 'hunt' or move up and down a bit due to atmosheric conditions and the swaying of the TV station's Towers.
Gee, Can you tell that I explain this often? Yea, I work for a TV Station in Cleveland. This switch has generated more than 700 phone calls all of which I attempt to call back on a daily basis. The public needs to be re-educated on this new system and how to make it work for them. Every installation is unique. In many cases, it will require the help of a qualified TV Antenna specialist to find the "Sweet Spot". Those of you in Apartment buildings, and anyone that may be a shut-in or senior with limited help or finances, my heart goes out to you.
Hope this helps!
Sep 09, 2008 | Televison & Video
Thomson DV3 digital terrestrial recorder
this recorder is constantly getting bad reviews, I think it is unfair because mine does the job, however this problem occured heres what you do.
turn off at the mains and wait 20secs turn back on and hold the standby button untill a light appears.
in sequence up down left right menu ok press the buttons on the front of the box wait 60 seconds and the normal red light will appear turn on box and there you go.
Good Luck further issues visit www.topuptv.com WARNING- doing this procedure will swipe your library but i think it is the only solution
Mar 31, 2008 | Televison & Video
Audio
How are you hooked up? I.E. terrestrial, satellite, ?
If the channel on HD isn't strong enough to pull the signal, sound won't play because it isn't locked. Because you have sound on non hd it is a signal issue not the tv.
Feb 16, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
