Question about Video Game Consoles & Games
Bluetooth ps3 How do you connect bluetooth headset to ps3? Already connected headset through USB.
MASTER RESET
At front of the receiver there is a button. Press it down for 2 seconds. Next on the controller, hold the left 2 shoulder buttons down WHILE re-inserting battery. Press the SQUARE button. Your controller should be working as normal.
Posted on Feb 03, 2009
  • bakhsho Feb 03, 2009
    Sorry this is for logitech control pads not for bluetooth headsets
Isymphony v1blue docking system, the bluetooth pairing function is not working, any ideas? Thanks
  1. Settings
    • If the Plantronics headset was working before, an unintentional change in settings may have resulted in the headset not pairing. Access the Audio Device Settings menu in Settings, and restore the default settings for headsets.
    Re-Pair
    • Resetting the connection between the headset and PS3 may solve the pairing issue. USB headsets only need to be connected to a USB port to be paired. A Bluetooth headset must go through the pairing process (see Resources).
    Functionality
    • If you're using a Bluetooth headset, confirm that it has fresh batteries and is receiving power. If possible, sync the headset with a cell phone or another PS3 to confirm that it works.
Jan 20, 2013 | Audio Players & Recorders
When ever i try to connect my bluetooth to my ps3 it will just keep on scannin for ever
Ah, very simple.
Turn on your bluetooth headset Go to wireless headset, press triangle for options choose connect, then press circle after. You've already got it done.
That's all I did and it works just fine, happy gaming!
Jan 31, 2011 | Mad Catz Bluetooth Headset for PlayStation...
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Cant pair ps3 wireless headset
sometimes it is easier just to watch a video!
Here ya go. please remember to leave me a positive rating and a testimonial really helps!!
thank you!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Pairing Problems:
  • If the PS3 cannot locate your headset, make sure that your headset is in pairing mode before you start scanning. The headset instructions will tell you how to set yours to pairing mode.
  • If your headset is missing from the device menu after you re-start your PS3, you will have to pair again. Many headsets will only "remember" one device at a time, so you may have to register again after using your headset with a phone.
  • If your headset appears on the Audio Device menu but is "grayed out" or not selectable, it is not connected. Make sure the headset is charged, and that it is on in standby. I should connect automatically when the Audio Device menu is selected. Tap the call button on the headset if it does not connect, or click on the Connect Bluetooth tab on screen.
  • Make sure no other Bluetooth devices are in use nearby.
Voice Chat Drops:
  • Most in-game voice chat drops are simply network lag. Usually they go away after a short time, so be patient. In extreme cases you may have to leave a game and return to reset the chat function.
  • If you use wireless internet, a low signal strength to your modem/router can make voice chat malfunction. Make sure your wireless signal is as strong as possible to your access point.
  • Sometimes a headset will quit after changing discs to another game. Go to accessories and select your headset again.
4. Playstation 3 Links and Customer Support:
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
I cant connect my headset
Have you charged headset via usb cable plugged into ps3...when charged press + hold silver telephone symbol...a blue pulse light should appear on headset..go to menu in ps3..to pair devise [headset] with Bluetooth.
Feb 26, 2010 | Mad Catz Bluetooth Headset for PlayStation...
My ps3 bluetooth headset wont pair with my ps3
go into accessory settings and connect the bluetooth device via USB so the drivers can be installed to your PS3. This is how i connected mine.
Feb 22, 2010 | Ubi Soft Entertainment Tom Clancy''s...
Can one get the plantronics audio 995 USB headset (with microphone) to work with the PS3? The headset uses 2.4GHz, not bluetooth, so it's not a bluetooth pairing issue.
I believe it should work...
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Dec 14, 2009 | Plantronics .Audio 995 Digital Wireless...
I ALREADY PAIRED THE MAD CATZ BLUETOOTH WITH MY PS3 AND TESTED THE AUDIO, WORK, FINE. BUT WHEN I PLAY GAME (UNREAL TOURNAMENT III ) AND TALK INTO THE BLUETOOTH I CANNOT HEAR MYSELF TALKING IN THE GAME WITH...
We have some new information:
(Click here)
Dec 04, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Insignia disk does not read from Playstation3
if the headset is bluetooth then the ps3 should be able to connect with it while its in pairing mode form the settings menu. if the headset will not function without other software then the ps3 cannot use them. the ps3 will only read the select music, video, and game discs.
Jul 25, 2008 | Insignia Bluetooth Wireless Headphones...
Video Game Consoles & Games Logo
437 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
