Question about Hotpoint WD62 Front Load Washer / Dryer
Clearing the pump for coins ect.
I THINK MY PUMP IS BLOCKED ON MY HOTPOINT WD62 MY LAST MACHINE HAD A PART AT THE BOTTOM THAT YOU COULD OPEN AND CLEAR i CANT FIND IT ON THIS MACHINE
  • 139 Answers
Hi this is an easy one but please rate me as.
Cool What you got to do with this machine is basically remove the back panel to get to the filter at the bottom of the drum.
What you will need is a pozi screwdrive and a pair of pliers for this job, and in most cases the filter is blocked.
So pull the machine out from and disconect the electric, look at the back of the machine and you will see a whole load of screws which to be exact there are about 9 small ones and 6 others which are slightly larger near the bottom area of the panel.
remove the panel by unduing the screws. once removed at the bottom of the drum you will see the filter which is connected by either a steel clips which you just squeeze and pull down the filter. inside is a plastic white thing and just pull it out with the junk in it and empty and clean.
replace filter and back ,, hey presto
hope this helps im sure it will
Washdoctor
Posted on Oct 02, 2008
My washing machine spins at end of its cycle, however, the clothes are still soaking wet. Will it be that the pump has gone as I've emptied the filter
most likely the pump is blocked......................small coins easily block em......
did 1 last monday and the pump had a penny pluss a wire from a womans bra..........
just clear the pump and job done.......
see if you can get machine near an open door first .....
let rear hose lay outside,...
it will help get some of the water away............
cheers
Apr 13, 2011 | Washing Machines
My daughters washing machine of 3 yrs old keeps stopping and flashes F 18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine..
Open flap at the bottom righthand flap.
Keep big bucket handy for water.
Remove clear plastic attached to black tube (slowly)
This will empty water from washing machine.
Once empty - no water coming out from washing machine then open big opener next to tube and remove any objects inside( coins, buttons and such)
Put back clear plastic filler firmly inside as before.
Close big opener next to tube.
close flap
Turn machine programe knob to DRAIN.
Start washing machine.
Should do the trick....
Good luck
Apr 01, 2011 | Washing Machines
My hotpoint washer has quit spinning all the water out of the clothes. Drum still spins but you can feel it hitting the sides of the machine as it goes around. What do I need to do to fix this?
THE DRUM SPINNING HAS NOTHING TO DO WITH MACHINE NOT EMPTYING..........
there is a seperate pump at the back of the machine....just follow the waste hose.........it may be blocked inside a small coin is perfect to clock it.........just clear it and see if it works..........
cheers
Mar 31, 2011 | Hotpoint Washing Machines
Machine won't spin
The most common reason for this is the pump is jammed - usually with a coin or sock or something.
The pump may be accessible from the front bottom of the machine - look for a little box open it - and you will access the coin - you can clear it and try again - remember to put the coin trap back together again.
Alternatively, if no coin trap is present you will have to tip the machine back - and look for the pump usually it has two black hoses going into it and it is situated near the bottom of the machine - remember when removing the pipes water will come out - so - have a bucket close by to catch the water.
you may find what is jamming the pump there - if there is nothing the next likely culprit is the timer... try moving the programme dial on a little bit see if the spin starts - if you have a digital machine there will be no way to try the last fix.
But the pump is almost always the problem!
Good luck
Jan 07, 2011 | Washing Machines
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Noisy spin on hotpoint wd62
comon fault on hotpoints is drum bearings put ya hand in the drum and give it a quick flick if it soundslike it rumbles buy a new washer.since merloni bought hotpoint you prob have to buy a whole drum not just bearings
Oct 03, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62
The most likely culprit here is a the pump, which may either be blocked, or broken.
You should be able to get access to the inside of the pump through a small hatch on the front panel of the machine at floor level. Beware - as you open this, really quite a lot of water is going to come out, so you'll need tomething to catch it, and you may need to shut the cover a few times if your container fills up before the machine is empty.
Once you've got into this space, remove all the loose coins which have accumulated there. If you think you found enough to block the pump and stop it working, put things back together and see if the machine is fixed.
If not, turn off the cold water supply, and run the machine in tumble-dry mode for a few seconds at a time while watching the pump impeller (looks like little fan) in the back of this cavity.
If it doesn't start whizzing round of it's own accord every time, then you need a new pump motor. These are cheap, readily available on the net, and straightforward to fit.
If the pump appears to start and run OK, then check for kinks and blockages in the hose that goes from the drum down to the pump, and in the drain hose that goes from the pump out the back of the machine. Finally, make sure that where the drain hose plugs into the standpipe (of whatever fitting is used in your part of the world to connect to the domestic drains), air can get in freely.
A.
May 18, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WMA30P
abi29
if you're looking for the lint filter, it's at the bottom where the door closes.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA35 - water will not empty and will not spin
Hi Debbie
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump)
There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller.
Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing.
If this does not solve your problem please give more info........
Feb 20, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint WD61
1, your pump may be blocked by fluff coins and other debris.
2. more likely bushes worn on the main motor not giving enough umphhh (loverly word) to go through a complete spin....Bushes easily replacable. Job start to finish with parts on hand a machine mechanic 10-15mins top Diy er like me an hour allways have trouble finding the right spanner... Good luck.
Jan 06, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
