Question about GE Spacemaker JVM1640SJ Microwave Oven
IN CABINET MICROWAVE
MY MICROWAVE IS ONLY ABOUT 3 YEARS OLD AND LIKE A BIG DUMMY, I PEELED THE PLASTED OFF THE INSIDE OF THE DOOR (I THOUGHT IT WAS SUPPOSE TO COME OFF), NOW I CANNOT GET OR KEEP THE INSIDE OF THE DOOR CLEAN BECAUSE OF THE MESH. QUESTION IS: CAN I GET MORE PLASTIC TO PUT BACK ON OR CAN I TAKE THE MESH OFF
  • 706 Answers
Hello JudyKitz,
That mesh is there to protect the user and acts as a shield to contain microwave energy to the cooking compartment. Never compromise that material.. You can purchase replacment liners at this site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130353 If you prefer, you can get a thin piece or sheet plastic cut to fit at many local hardware stores or home centers..You may want to make a paper template or take accurate measurements with you for that method.. Hope this helps you..
Posted on Oct 03, 2008
The bottom inside part of my Oster microwave is peeling up pretty bad where the plaste circle with wheels turn the glass. Don't use it much for this to happen....is it still safe and is there any recalls...
Using the microwave with exposed metal can cause additional problems. You can remove the loose paint, lightly sand the area and reprint with microwave cavity paint. The paint can be purchased from your local parts distributer, or find it online. Follow the instructions on the can.
Jul 21, 2014 | Microwave Ovens
PROBLEMS WITH MICROWAVE OVENS PEELING INSIDE
It`s not you that`s caused the problem, it`s the condensation from the cooking which gets under the paint, It`s worth investing in a stainless steel lined oven. Ian
Jul 08, 2009 | Sharp R-820B Convection/Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Remove a microwave oven
To remove this model from instalation:
1. Disconnect the vent pipe from m/w (inside the cabinet on top of m/w)
1. Unscrew 2 big screws from the top (inside the cabinet).
2. Tilt it to you a little.
3. Lift it up and m/w can be removed.
Dec 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Small tear on plastic lining covering the inside of the door
That clear cover (sometimes called the inner door screen) is very important.
It protects the metal mesh / screen from debris and corrosion. The metal screen allows you to see "what's cooking" (*grin*) but prevents microwaves from leaking out of the door due to the precise size of the openings in the mesh.
If the mesh rusts or gets grease or food on it, it can arc, and this can damage the screen, then microwaves can leak, causing a burn or fire hazard. (No "radiation" threat, though)
If no arcing or other damage has occurred yet, you can clean the area squeaky with alcohol, then dry it completely and use the smallest possible amount of clear Scotch tape or packing tape to cover the tear and make sure it's flat.
If this fix doesn't work, or it's too big an area, you will have to replace the sheet, which can be ordered.
You'd have to heat it up with a hair dryer, peel it off slowly, then clean the area with something like acetone, then peel and stick the new one.
If you need to or prefer to order it, I would need your brand and model number to help you further.
Oct 05, 2008 | Microwave Ovens
PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing.
Aug 10, 2008 | Sunbeam Microwave Ovens
Microwave door has burnt patch: is it safe to operate?
From your other post:
The paint should be available at big box stores like Wal-Mart, home improvement centers like Builder's Square, Lowe's, or Home Depot, or hardware stores or local appliance parts stores.
You can order the plastic sheet (called the "door film") here. It is part # WB06X10490.
Be sure the mesh is clean and dry before installing the new film.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | GE JVM1653 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
132 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
