HP LaserJet 2420 Printer Logo
Susan Starrs Posted on Dec 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an HP laserjet 2420 which has suddenly started making an alarming cracking noise when printing. I have checked the papertrays and nothing seems to be amiss. Any ideas?
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Dec 13, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
450723
Points
2591
> Are you observed this noise while printer initializing?(after switch on the printer)>Remove back cover, check the fuser assm screws, tighten or slacked?>If found any slacked, replace little lengthy screws then existing screws, ensure that don't try to do fully tighten the screws.>Put more pressure to tighten the left down fuser screw.>Replace 20t fuser driving gear.
I have an HP laserjet 2420 which has suddenly star - 12_13_2011_5_59_57_pm.jpg
2420 printer printing very squiggly as if you are looking at a reflection in water that has currents in the water, this is not a toner issue
Looks like you have a clogged/possibly damaged heads and head alignment issues. Do the alignment procedure and check the manufacturer support website or Google for the factory reset button combination of the printer. Cheers, Mike.
2answers
Where do I load the original to be copied on this printer. I don't have the manual.
Here's a few links that might help you with the printer in general.
The HP LaserJet 2400 Series Manual - This covers 2410/2420/2430 HP LaserJet Printers. I uploaded it to my dropbox and this is the shared link for the .pdf file.
HP Laserjet 2400 Series Software Manual - 2410/2420/2430 LaserJet Printers
Here's the HP2400 Series Software Manual - I've also uploaded this to my dropbox account.
HP LaserJet Printers - Steps to Print Manual Duplex Using the Application Settings or HP LaserJet Driver Settings
My hp 2420 pcl 5e STOP PRINTING SUDDENLY. & showing me (FUSER ERROR) TELL ME WHAT CAN I DO TO SOLVE THIS PROBLEM I TURN IT OFF AND BACK ON 3 TIMES BUT PROBLEM IS STILL THE SAME.
Hi
Problem either fuser faulty or dc controller card faulty first check for faulty fuser & after then dc controller fuse of fuser.
Thanks
2answers
Hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
8helpful
Duplex printing in HP 2420dn
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
2helpful
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
HP 2420 Faded Print outs
Check (and remove) the "economode"in "Printer Preferences" (right click on Printer applet) normally in "Paper /quality" Tab
HP LaserJet 2420 printing problem
Hi all of you
  • try use another data cable.
  • If the printer work proper before do system restore.
Hope this fix your problem,
Thanks
Hamedo
HP LaserJet 2420 Printer Problem
Go into your print setting and check the box the has 'print on both sides'. It can easily done if you installed the HP toolbox software.
HP 2420 sudden prints pages in all black
Most likely to be the toner cartridge is it OK on other programs such as the web explorer? If not change the toner cartridge you can also print out the configuration page by pressing the green tick and then using the up and down arrows select information press green tick to enter then move to "Print Configuration" and select using the green tick. If the page comes out OK then the print cartridge if fine if not try changing it. Also there maybe in the driver you have under printing preferences negative mode make sure that is not checked.
Failing this reinstall the print driver from HP Online if this still doesn't work then change the data cable if still not working then I suggest that the printer formatter board is faulty.
I do hope this helps you and please rate me
Thanks J
k24674
Grand Canyon Tech
Grand Canyon Tech
