Question about ASUS A7V400-MX Motherboard
Prosser runing at 100 persent
I have a12-21-04 A7V400-mx with a 1660mhz AMD processor. that runs at 100 persent. I was thinking of putting a bigger processor and or a new motherboard in. can that be done with out losing info on hard drives? what motherboard combo do you sugest? I have lots of music and pic files. Any Sugestions ?? Thanks. Michael
  • 1,472 Answers
In regards to your question about upgrading your system mainly if you change out the main hardware you will need to reinstall your operating system, I will assume that you have Windows. However his does not mean you will lose your data.
Normally if you have to replace the motherboard on your system unless it is the same model board you will need to reinstall Windows. Now with the CPU upgrade you may not have to depending on the differences between the new and old CPU but it is a good idea to do any ways. The reason for the is that when Windows is first installed on the system it scans the system to see what hardware is there then installs the right drives needed to run the system properly.
Another way to look at is a human we all have the same parts. However I can not just give you one of my kidneys if you needed it. You have to make sure that it is compatible with your system. The same thing is true with computers. So that is why you will need to reinstall Windows. Note you should be able to change out the other hardware with out any trouble, except the HD of course because it has your operating system on it.
Now comes to the part with your data. There is a couple of ways you can does this. Ether you can back of the data to CD or DVD. If your have a 2nd harddrive you can move the data over to it then format the first one to reinstall your Windows on. The easiest option is if you do not have another harddrive or want to add another one is to buy a new one. Then you can make this the drive that you reinstall Windows on and keep all you other data on the other drive.
Hope this helps
If you have any more problems and/or questions let me know.
Posted on Oct 02, 2008
What's your problem?AMD athlon 2Ghz processor will suitable for asusp5gc mx x-series motherboard
No... Absolutely not.
You can't put an AMD processor in a motherboard that only supports Intel processors.
Aug 17, 2012 | Intel Computers & Internet
Can i fit a bigger processor to my ASUS K8V-MX Motherboard and mybe more ram and if so where can i purchase it from
This motherboard supports a AMD Athlon 64 / Sempron processor (Socket 754). Since this is an older unit you will have to search on Ebay for a processor.
As for the RAM you will need DDR 400, this can easily be purchased at There is a maximum of 2 gb on your motherboard.
Mar 17, 2011 | ASUS K8V-MX Motherboard
A7V400-MX Motherboard: I have changed the processor on my mobo, and I wan...
Based on the user manual starting v.2 dated April 2004, this mobo uses a dip switch array to set your processor and bus speed.
You will need to set the correct processor speed based on manufacturer [AMD] description.
Visit this link and see page 23 to set the switches as needed for your new processor.
May 18, 2010 | ASUS A7V400-MX Motherboard
Motherboard shuts off
You may want to try using another power supply rated at 300W plus. Also make sure your RAM is unbuffered and non-ECC. To set the switch correctly, you need to goto look at the exact model number of the CPU. Because CPU with similar marketing name could have different front side bus speed.
One more thing to look for, make sure there is no metal standoff sticking out of the bottom of the case shorting out the mother board. But my first guess is the power supply.
Sep 02, 2009 | ASUS A7V400-MX Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
Motherboard cpu
The motherboard you listed supports AMD processors, (AMD Athlon XP/ Thoroughbred/Barton)not Pentium.
Jul 13, 2009 | ASUS A7V400-MX Motherboard
Amd 2800+
tried another motherboard ? that will tell you if you git a burned processor
Sep 09, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Possible motherboard problem ASUS A7V400-MX
i lost original cd...i need CD drivers for this motherboard ASUS Board A7V400 MX please help me. thx
Feb 15, 2008 | ASUS A7V400-MX Motherboard
Audio Driver
Do a google search for "A&V400-MX Motherboard driver" and there are plenty of sites to download the drivers from, such as this one:
Then run the installer if it's there, or right click on the .inf file and "install" it. There may be instructions with the files you can follow to install.
Nov 09, 2007 | ASUS A7V400-MX Motherboard
ASUS A7V400-MX Motherboard Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
