Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi 50500A Tv won't turn on
Before the tv just went blank with no sound or picture it had too much yellow in the picture and would not adjust out. Also had a large red circular area in the picture. The other night while watching tv it just went off as if it was turned off by the remote. No sound, no picture. When you try to turn on on blue dot lights up and two red dots. All lights blink and then the tv just shuts off. One red light is labeled temp and on is labeled lamp. Please help me. I don't know whether to fix this tv or just buy a new one. It seems to have more than one thing wrong with it.
ctf1800
  • 4402 Answers
SOURCE: Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SOURCE: Blue Dots
I have the KDF 42WE655 with the same blue dot issue and Sony upgraded me to the KDL 46V4100 for $375! I jumped on the opportunity.
Posted on Sep 02, 2008
  • 927 Answers
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Posted on Sep 09, 2008
SOURCE: hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Posted on Dec 07, 2008
  • 14 Answers
SOURCE: RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Posted on Jan 11, 2009
Hitachi plasma p55t551 screen went blank but still power on n good sound
Any number of issues including power supply to main board are possible------Have you removed power from the set and or a box if used for a while?
Nov 05, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Was watching tv and it suddenly went blank. I hear it turn on but no picture or sound. What might be the problem and how costly to repair
sounds like a high voltage problem, could be the horizontal driver or something in the high voltage section.
Sep 14, 2009 | Hitachi 35CX45B 35" TV
Hitachi model 57SWX20B , Sound, but no picture
I had similar problem with my 57xwx20b TV as well. I'd unplug it from the wall for at leas 30-40s and plug it back in, the picture would return as normal. It will come back from time to time but the same procedure will reset the video board and the picture will return. I'd also check to make sure that the TV has the latest firmware from Hitachi as well. The FW for the ATSC tuner is upgradeable via the SD card and Hitachi website will give you the procedure. This fix all kind of problem with my TV from blank screen, green screen, flashing screen, pinkish screen because the old FW was built before the final standard. Apparently, it interferes with the video board and causes it to go amock. Good luck.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 60vf820 ultravision
Good Day, bgblueeyess;
Your somebody is wrong; replace the LAMP.
Aug 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Projection tv no picture has sound no picture
Try resoldering the vertical output IC. The crts may be blanking due to vertical deflection dropping out.
Apr 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
1998 50" Rear Projection Hitachi Model #50SBX70B--NO picture
can you see the g2 from crt sound like you list your g2 from
the flyback.i need m# plz
Mar 30, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi screen went blank?
1) Consult service manual for details.........procedure issues?
Sounds like the digital convergence unit got confused....
You may have to start all over again at default....
2) When converging a PTV, less is better ( adjustments) unless
you are positive adjustments will yield some improvement..
3) Info source = www.HitachiServiceUSA.com
Please rate this solution.............................
Nov 03, 2007 | Hitachi 43FDX01B TV
Hitachi 43FDX01B
You likely have a fuse bad on one of the supplies to the convergence output IC's.  check EP96 and EP97.
Sep 27, 2007 | Hitachi 43FDX01B TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
