Question about Sony CDX-S2200 CD Player
Sony CDX-S2200 CD Player Problem
Unit was working fine. Suddenly cannot switch on (on switch does nothing). Discovered the CD eject button now turns unit on (lights come on) but no sound, no operation - tuner or CD. All other buttons appear disabled. Pressing CD eject again powers unit off after 3 seconds.Have disconnected and left overnight to discharge any capacitors etc. Reconnected - no different. Halfords cannot explain it. I have a CD stuck inside - any suggestions on how to get it out ?
  • tormore Oct 03, 2008
    OK thanks. Tried the reset already so looks like it is bust. (Bought a new one tonight).
  • 10,594 Answers
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Posted on Oct 02, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
Cd error message on head unit on alpine r990,this is connected to a sony cd changer,has been working fine suddenly packed up.Now when cd button pressed no indication on radio screen,boght another stacker...
Hi John, when you think about it, it could only be one of two things either the bus lead or the RCAlead as everything is in them leads to run the cd unit, So check that all leads are secure to see what happens.
Feb 05, 2010 | Alpine CDA-9885 CD Player
Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Avh-p5700 pioneer
My first suggestion is to not purchase "used" electronics from eBay. I bought the same kind of unit from eBay... and mine is broken too. I got a cell phone, car stereo, and a remote.. they were all not working properly when I received them.
Did you try the restart button. It is a small, pin size button on the right-side of the unit near the 4-way select buttons. My player wouldn't eject a cd either, and when I pushed the restart button with a pin, the cd ejected and the unit was ok for playing cds... that's about it
May 04, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Feb 17, 2008 | Sony CDX-L480X CD Player
Sony CDX-S2200 CD Player Logo
746 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
