Jrg electric fire mod jrg 930 how do you get access into element area
How to get access into element area
  • davmcg Dec 06, 2008
    jrg electric fire is blowing cold air.
    can it be repaired?
There are two retaining screws partially hidden at the bottom of the front grille. Remove these two screws completely. Then slide the whole grille downwards until the two top retaining tabs are exposed. Lift off the grille.The elements are retained with springs. Push the element deeper into the LH socket until the RHS is free and then remove.When replacing the grille make sure the bottom edge is in first, then slide upwards until the tabs are located in the slots, and replace the two screws.
Posted on Apr 18, 2012
I have 4- kidde fire extinguishers. What are the recall mod. #s and procedure for replacement?
long list either go to kidde site and they can advise and also for locations in your area or a seller in your area
Nov 03, 2017 | Home
How to replace bottom heating element in whirlpool mod-GR563LXSB? this is a floor mod electric stove
In most cases you unplug it from the power, take off the back, locate the wires to the element, remove the connectors and retainer nuts, go to the front and remove the element, replace it in reverse order.
Feb 04, 2017 | Whirlpool Kitchen Ranges
Something went on fire behind the fan,there was a buirning smell and there was orange light coming from behind the fan. Now the oven wont heatr up
That fire and burning smell was your oven element burning out. The element is located directly behind the fan. This is why your oven will no longer heat up.
If you are going to replace the element yourself, there are some universal elements available (try eBay) much cheaper than the OEM replacement parts. You need to make sure it's the same rating though (e.g. 2000W) and is roughly the same dimensions and has the same fitting pattern.
You will also need a service manual unless you know how to get access to replace the element.
Oct 06, 2010 | Neff B1421 Electric Single Oven
Good Day,
Most dual element water heaters do not run both elements at once, so it is common to get 0 VAC at the bottom. It will not kick in untill the upper thermostat tells it to. The most common cause for a new element to blow like you describe is dry fire. Make sure you open the tap and or t&p and bleed all the air out of the tank before hitting the power. Hope this helps.
May 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The bottom oven element does not ignite. the broiler is ok . a fire was put out with an extinguisher. no noticable damage to the element... what else can i check/ clean?
Unless you had a big spill in your oven, a "fire" in the oven is almost always a result of a burnt out element. Look very closely at the element for a rough spot. Look in the area where you noticed the fire. (that would be where the magnesium inside the element burned) The only easy way to confirm the element is good or bad would be to ohm check it with the power off and at least one wire disconnected from the element. Other than the mess, the fire extinguisher would not cause any damage to the oven.
Oct 16, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Sep 12, 2009 | GE JTP45 Electric Double Oven
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
Element Melted - Turned White Hot/on fire and would not go out
You need to replace the element. Very easy to do. Cut power off at the breaker or unplug the stove FIRST (please!). Remove the two 1/4" screws securing the element to the oven cavity then two wires to the element just unplug. The wires can go either way. Call 1-800-626-2002 or go to the GE Appliance web site for the part. It is a WB44T10011 for the lower (bake) element and WB44T10009 for the top (broil) element.
Jan 02, 2009 | GE JBP80 Electric Kitchen Range
GE Hotpoint Dryer NVLR333ET0WB
ck for thermal fuse on outer edge of element housing it usually a small round disc
Jul 23, 2008 | Kenmore Elite HE4 Electric Dryer
Heating & Cooling Logo
337 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
