Question about Splendide 6200
Washer pump handle broke same time as pump and controls broke have clothes in washer canr get them out . Setting knob wont set will start clicking through cycles . Help need clothes
  • Anonymous Mar 17, 2014
    at first the washer would not pump out the water. My wife unplugged the unit and I removed the filter and some coins. We plugged the unit back in and the water was pumped out. She tried a load of clothes and had multiple flashing lights. We than pulled the strainer and emptied the water out of the washer. After connecting the washer back up we got the start and prewash flashing lights and the washer wouldn't do anything.
Unplug the unit for 10 minutes...then open the door.
Posted on Sep 28, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
WHY IS WATER LEVEL LOW CAN I CHANGE THE SETTING ON WATER
there should be a knob on the control panel showing small, medium, large maybe even super. that is how you change the water level. Its for different amounts of clothing your washing at a time. If you put in a few clothes then you have the option of using less water.
Jul 31, 2014 | GE WBSR3140DW Top Load Washer
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Low hot water flow on delta single knob tub shower on/off control
The cartridge and sping+washers will most likely need to be replaced.
Oct 07, 2009 | Plumbing
Removal of the washer control knob
Anyway the model I got on your problem says it is a Refrigerator...but I can help you to remove the Knob on a washer....first you may have to place a flat head screwdriver in between the knob base and the control panel ..(You may want to place a piece of cloth against the control panel to prevent scratching the surface of same)..slowly force the screwdriver further under the knob alternating form side to side gently lifting up as you do.....(all of this is is premised on the the notion that there is no set screw in view anywhere on the knob)....also most all washer knobs are held in place on the shaft with a little spring loaded retainer that pushes out against the inside of the knob so it does not easily come off.
Hope this helps...please rate me...the Fang
Mar 26, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I Have the same problem! Please Help!
Try tipping the washer over forward and look to see if the belt is still in place. If so, make sure it is tight. Have you tried setting the control knob on the control panel ahead a click at a time manually?
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hard to start dryer, control know loose/misaligned
your saying that pulling the timer knob out, which normally starts dryer, does nothing. however if you pull out and apply pressure upwards on knob and touch nothing else, the dryer will start??? if the thats the case sounds like a short in the timer mechanism , youll need to replace the timer assy
Mar 18, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Splendide 6200 Logo
135 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
