Question about Hotpoint WMA30 Front Load Washer
Hotpoint WMA30 Front Loader Not Pumping Out but still fills if put on rinses, on spin tries but gives up
Hi
During a cycle it would not Spin, as there was not a lot of Water I opened the door and removed most of the garments.
Then Tried the slow Spin again, after trying a few times it gave up on spinning.
I thought the programmer may have got upset so I switched it off on the front. Left it a while and then tried the Hand wash programme it worked up to the pont of spinning where it stop. I noticed that there the drum was about 25% of water. So I guess the water is not getting pumped out.
I tried the Slow rinse programme but all that happend was that it filled with more water and is now about half full of water. Clearly it is not pumping the water out and I cannot hera the pum working so may be it thinks their is no water init., but I would have thought it would have sensed this and not added more water. Before I take it about have you any idea what can be wrong and how is the best way to get the water out
  • mohd_yousufs Nov 12, 2008
    i started using the water is a not pumping out i tried ofn all different sections but i couldnt get it its spinnnig for a while but not pumping out the water but i tried everything.\
  • dmrtheref Dec 28, 2008
    the lights are not working and it will not reset and i have changed the fuse three times even though they were not broken? Installed the WMA 30 washing machine and it filled up with water and it did nothing else so i tried to reset it and it still has not reset ?
    President:
  • 1,462 Answers
No easy way to get water out but try putting drain hose down at floor level into a bucket and that may work
fault is probably filter blocked.
to access filter, take rear back panel off. you will see a large diameter hose going from bottom of tub to pump. disconnect this hose at tub end - carefull, water will come out. filter is inside this hose. take it out, clean and reassemble
Posted on Oct 03, 2008
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
All my clothes smell mildewede
the washer is not pumping out the water correctly ---- try some different wsh cycles to see what happens --- make sure it drains during the spin and rinse cycle
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
My washing machine wont rinse and spin, after washing it will beep as if it was finished doing the washing.
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
Apr 17, 2009 | Hotpoint WMA30 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint - wont go into spin!
two possible causes motor commutator is damaged thats the bit the brushes sit on.put your finger on the commutator turn slowly and feel for raised segments or damage if there are any then this is you problem. if that is ok check you brushes have a good length and can make contact. if this is ok then check you card for damage.the filling/water level problem could be due to the limit switch pipework blockage at the base thats the small plastic pipe usual blocked into drum very common in old machines. hope this helps
Dec 01, 2007 | Hotpoint WMA30 Front Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
180 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
