Its a orion xtr subwoofer
You can, but I wouldn't advise it. Won't sound that great, your probably going to overheat your amp. It may go into protect mode. You need a bigger amp.
thanks...what amp would u recomend
thanks what amp would u recomend
Is it the XTR 154? Or XTR pro 152?
You need at least a 500 watt mono block for 154. If you have the 152 pro you need at least 800 watts to push it
And your very welcome sugar :)
i wasnt sure so i looked it up by comparison and it says its a xtr 15d idk it just says orion xtr 15 on the actual woofer
Since you say its 500 watts I'm going to assume its the 154. I'm not sure if it was you or not but did you post a question about wattage? Your amp says 500 but only puts out around 250, you have to keep I mind your amp is the way, only putting out a percentage of what it says of constant power
i kno nothin about this it came with my car as well as the amp.. tryna learn more about it before i begin setting it up
I meant your sub says 500 watts, my apologies :)
yea it was me
For sure, its good to do a little research. Don't want to damage anything.
its good thanks for the help...what brand would u recommend for best quality
I would go with fosgate, alpine, kicker etc... something better quality with a truer power. Make sure its mono block. But don't go over 600 watts, or you may damage your sub
