Question about Samsung Prostar DCS-24B-LCD Corded Phone
One touch speed dial key
How to get the SPD button to work again... I was programme other speed dial keys and disable this key somehow. Meaning to press the SPD button to enter preset XXX's.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Watch this video which shows you how to program your soft keys. more like this are at http://abbeytelecom.com
Posted on Jan 28, 2011
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i store numbers? there is no manual.
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
Sep 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I am trying to change a name on our systems telephone speed dial list and we have a KX-T7630 any help will do.
This name is stored in the main system processor, not the phone. On the phone, key in *#1234. display shows "sys Prog.
Key in 002 then press NEXT. Disply shows Sys SPD. Name . Enter the speed dial code that you use for the name you wish to change i.e. 000 to 999 followed by NEXT. The existing name will show on the display. Using the keypad, just like your mobile 'phone, key in the new name. For example, for John you would key in 5, then the button under the display with J, then 6 and the button under O etc. When complete, press the button marked "Auto-Dial/ Store followed by the hold button followed by program button
Aug 25, 2010 | Panasonic KX-T7630 Corded Phone
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I have a few issues right now with my LCD 12B. 1. I have been trying to program one of my programmable buttons to be able to speed dial an outside number with just one touch of the button. I am having...
Hi, rather than try to send you written instructions you need to watch this video, then go to http://www.abbeytelecom.com and search 'programming the soft-keys ( they need to be an SPD)' then search 'how to add members to a group' and add the extension back into the operator group. hope this helps!
Aug 04, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
How to program the programmable keys to an external number
The programmable key has to be an SPD button, you then enter the speed Dial entry number. To do this go to Youtube and follow the training video which I have loaded for you, this explains MMC 722, you must have that specific phone number in the speed dial directory, again this can be found at Youtube search 'abbeytel'
Dec 14, 2009 | Samsung Phone PDCSLCD12B
I need to recall the system speed dial directory on my NEC Electra telephone system. I am unable to find a memory re-call/display feature in my manual.
With this old model of phone you don't have the soft keys to scroll through the directory like the newer models have.
In order to check the system speed dials you will need to check them manually:
System Speed Dial #'s
LNR/SPD key and the system speed # 00~79
Station Speed Dial #'s
LNR/SPD key and the system speed # 80~99
This will dial the # and/or display the name associated with the speed dial.
In order to program them refer to this manual:
Elite IPK Features and Specs
Look under Speed dial-Station or System.
Nov 11, 2009 | NEC Electra Professional ETW-16DC-2
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Samsung Prostar DCS-24B-LCD Corded Phone Logo
115 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
