Colby dvd -215 i switched vidio options and cannot see it can it be reset?
I switched the picture to a different setting in the menu and cannot see any thing .i only have regular av cords so icannot see picture just sound. is there a way to reset the dvd player with the remote ?
  • 68 Answers
Try this
*********RESET THE DVD PLAYER BACK TO THE DEFAULT SETTING*********
Make sure you do not have a disk in the tray. Using the DVD player remote control:
1) Press the "Setup" button.
2) On the "Right" arrow, press it three times and then press the "Play" button.
3) On the "Down" arrow, press it two times.
4) On the "Right" arrow, press it once, and then press the "Play" button.
5) Press the Setup button.
*The default setting will take affect as soon as you press the setup button (step 5).
Posted on Oct 02, 2008
I have a presidian dvd recorder, that i haven't used for a few months and i hooked it up to my cable box and i cann't get the vidio to work, like it should be reset? Thanks
You likely have two video input options, s-video and composite (also known as RCA or A/V). All you need to do is change which connector your using in the settings. Look for a button on your remote that says SETUP or OPTIONS. Once you push it, you should get a settings menu. Look for something like REQUIRED SETTINGS or SYSTEM SETTINGS. Play around with it, and you will find the option to select between the connectors.
I hope this helps! :-)
Mar 05, 2011 | Dual Presidian DVD Recorder
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Screen save stops displaying
If you go to Start Menu --> Control Panel --> Power Options --> then look the option that allows you to change the amount of time that the system turns off the monitor because of inactivity.
Apr 15, 2009 | Toshiba Satellite A215-S7422 Notebook
Want to listen to music while still watching football game
Some receivers with video switching have the option to stay on the video source when you switch to a different audio source, others don't. I have a Yamaha that will do this while my Kenwood will not because the CD and DVD input are one in the same. I guess it depends on what input you are using for your music input. If it's a DVD input it makes sense that when you switch the audio the video follows. Try connecting your audio source to an audio only input (say the CD input) and see if that will allow you to do what you want.
Oct 09, 2008 | Denon AVR-3803 Receiver
WD 57733 picture color problem
Good Day;
Try resetting both devices TV & BOX, unplugg power for 2 to 5 minutes then plug back in.
good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dvd finalization
I turned off the Colby recorder then turned it back on and inserted the DVD and chose the edit button on the remote controller. The correct menu with the close and finalize choice became available.
May 26, 2008 | Coby DVDR1280 DVD Recorder/HDD Recorder
Won't play purchased dvd's
i,d suggest laser head problem.
Dirty-weak laser unit. try a head cleaning disk.
Mike @ compurepair.
Feb 25, 2008 | Amphion Mediaworks T342 System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
