Question about Sony Cyber-shot DSC-S600 Digital Camera
Camera won't power up.
Hi. My wonderful camera is having problems. I turn it on, and it behaves as if the battery is flat - flashes the blue Access screen, and sounds the 'turning on' chord, but then shuts off. I have tried recharging the batteries, and also replacing the batteries with completely new ones. But new batteries don't solve the problem. (It's a Sony DSC-S600, new in March 2006.) What would you suggest?
  • 10,594 Answers
Please check battery terminals inside battery compartment got clogged or black. Clean them with alcohol or some thing and should be shining.
I have seen few DSC-S600 with same problem and got repaired.
Posted on Oct 02, 2008
I have a coolpix L23 and she turns off for no reason, and when im trying to record when i click on the button it shurts down. have any ideas of what the problem might be?
Please make sure you have a good FRESH batteries. The batteries you are using may be old or discharged. Wen a camera behaves like this always assume power or batteries.
Feb 11, 2017 | Nikon Coolpix L23 Digital Camera - Blue...
Sony dsc w50 quit working
I think the memory card is full , try first taking off the battery and putting it back.
If the camera still does not work, try a different memory card.
If you still have problems, try going to setting menu and reset camera settings.
Sep 22, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
No flashing blue light when charging. Lens will not return into
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or possible alternative a new cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 28, 2009 | Kodak EasyShare M1033 Digital Camera
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
My camera wont stay on after i turn it on
Hi. It can be a problem with flash capacitor. To check if it is the case you should be able to power your camera at least for 10 seconds. If you can not power your camera for this time from batteries, try to use external DC 7.4V 2A power supply. After powering your camera just follow this procedure. 1. Turn on the camera. 2. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 3. Turn off the camera. 4. Turn on the camera. If after these operations camera can be powered from batteries and you can make pictures than the problem is in the flash capacitor which should be replaced. Or you still can make pictures with your camera without using a flash.
Jun 10, 2008 | Canon PowerShot S1 IS Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Sony cybershot DSC W50
when I turn the power on screen is blue with "access" message. after a few minutes, message is replaced with "turn power on and off". I have removed and recharged battery but keep getting the same message and other functions of the camera will not work.
Apr 30, 2008 | Sony Cybershot S650 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
110 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
