Question about HP LaserJet 4 plus Printer
HP LASERJET 4PLUS
HI, I CAN'T GET MY PRINTER TO PRINT, IT SAYS 00READY BUT IT HAS ABOUT 10 DOUCMENTS IN THE QUERRY AND I CAN'T DELETE THEM.THANKS REDBALL
  • 138 Answers
If you are using windows XP here's the process for deleting the jobs in the print que. Click "start" on bottom left on desktop screen of XP. Then hit the "Printers & Faxes" icon. Double click on your printer. When the window opens up highlight the first item on the list and hit delete. The first print job should be clear in a short time. Continue with the next on the list until the print window is clear. Close the window and try printing again.
If this has helped you, please rate it with a FIXYA!
Posted on Oct 17, 2008
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
Printer hp laser jet 4plus
you need a new fuser Its easy to change Just a screwdriver. I have a fuser for 60.00 and can tell you anything you will need to know. It should take about 4 minutes to complete. 805-520-3003
Feb 13, 2010 | HP LaserJet 4 plus Printer
After installing a new toner cartridge in my HP Laserjet 4Plus, I have an error code 14 no toner cart and cannot print.
1. Reseat the cartridge. Try a new or know good cartridge. If OK, stop.
2. Check the Hi Volt contacts on the cartridge for damage. If the contacts are dirty or damaged, clean the contacts after the repair.(This is especially important if the cartridge is recycled.) If OK, stop.
Before going further, evaluate the cost effectiveness.
3. Replace the Hi Volt Power Supply. If OK, stop.
4. Check and reseat the HVPS cable
5. Replace th DC controler
Oct 07, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
Error 51 HP 4Plus laserjet printer just stopped and error 51 appeared cartridge replaced replaced repair kit
Hello sir; 51 often in this model, change laser assembly( C2037-69008 ). next tryDC controller ( C2037-69004 ).
Mar 08, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
