Dear,
if it is under warranty then the best option is to send it back for warranty claim..
if u try to do anything else and maybe some other damages then its a big palanty for u dear..
so do that decision..
regards,
Replace both convergence IC's for reliable repair.
Part # Stk392-110 X 2.
I will first start out by saying, it is very important that you have some soldering experience working on solid state printed circuit boards and that you know that too much heat from the soldering iron will most likely ruin the pc (printed circuit) board. If this happens, it can be a very difficult repair. The boards are no longer available for these sets from Mitsubishi so I cannot stress enough, if you have no soldering experience, let a pro assist you in this repair. One more very important thing to remember and NOT DO!! If the convergence is way out or cannot be adjusted by the customer controls, do not go into the service menu and try to adjust the convergence.
will first start out by saying, it is very important that you have some soldering experience working on solid state printed circuit boards and that you know that too much heat from the soldering iron will most likely ruin the pc (printed circuit) board. If this happens, it can be a very difficult repair. The boards are no longer available for these sets from Akai so I cannot stress enough, if you have no soldering experience, let a pro assist you in this repair. One more very important thing to remember and NOT DO!! If the convergence is way out or cannot be adjusted by the customer controls, do not go into the service menu and try to adjust the convergence.
I know you are feeling this is not fixable, but it is. First, let's establish your TV is a Samsung HCM/PCL Television. Akai, is just a name licensed to this model. Having said that, the link below is the actual technicians service manual that pertains to your television. Below that is my advise as to how to handle this matter. If you feel this is something you wish to tackle on your own, in the manual, in the schematics in the back (Section 10-17) you will find the Convergence IC's. Thses are the one's in question and need to be replaced.
Also, I will say I recall at one point a few years ago that Samsung had a recall for models similar to this for coolant leakage and fixed them free of charge. You mau wish to call them (I was right ) If you have one of the Samsung projection TVs listed below, and the CRT coolant in the TV has leaked or is leaking, please call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number and serial number of your TV set on hand when you call.
http://www.techlore.com/downloads/file/7...
Two conditions will affect this, first is leaking crt onto the deflection
board, very common with Samsung, Akai RPTV CRT SETS. Second in failure in
the convergence dynamic output circuit or the fluid has also gotten to the
signal circuit contaminating the DCU assembly. In depth diagnostics required
to assure that there is no coolant fluid leakage, and if there is, what is
damaged. BTW the crts come with the yokes attached. When changing any of
them for leakage order the crt circuit boards (complete 3 card assembly with
focus assembly) also. What a nice design!!
As Mentioned, nothing that the average consumer can address themselves, have
it serviced. BTW you will not want to handle any of the internal components
if indeed there is coolant leakage!!
Let me know if there is anymore help you need. I would like to see you get this resolved. Just "ASK ME".
Ginko, why are you so full of **it. I am getting tired of you lying to the poor people about their problem and giving them the impression you know what you are talking about. Stop doing it or I will have you removed as a poster. This is my last warning and your last chance. Stop BSing prople. Alsdo, if you rated this yourself, you are gone. If GUERICH did not rate your solution, I am seeking to remove you from the service.
Sorry GUERICH forthat, but this individual is giving this service a black eye and we needed to warn him. Hope to hear from you soon.
Check ur internal mother board circuit..it may be an ic problem
If it is a projection TV , like the model in title, then it is not a convergence problem.
Describe the problem in detail and confirm the model number for the TV.
Shadows on lpd TV can be caused by lamp problems, on some models with projection LCD there are also problems caused by the anti polarizing screen on top of the display.
Blue and pink shadows are also caused by cooling problems in the light engine, in this case the fault will be expensive to be fixed.
Provide exact model, and more details on your fault.
If the unit is still under guaranty you can get support by calling the number listed on the owner manual.
how do i do that?
no it was not helpful.
i already gave you the info on the tv.
akai 42" pt4298hd.
if it was under warranty, i would have sent it back. do you have any other suggestions?
