Question about Kitchen Ranges
When i turn on the oven the top hobs keep clicking on my canon cooker
  • 750 Answers
Hello Brian
Welcome to Fixya.
You said, when you turn on the oven the top knobs keep clicking on my canon cooker.
If you mean the electronic ignition keeps clicking when you turn the oven, It sounds like one of the switches that is controlled by the knobs, is stuck and malfunctioning! It sounds like it needs to be replaced.
There are 5 electronic igniter's on a 4 burner gas range, and the fifth is in the oven.
Let me know how you do.
Please remember to leave a rating when you finish.
Thank You, Huuum
Posted on Oct 02, 2008
I have a Belling DB4 90Ei Cooker and I have noticed a hole in the back of each oven. Why is this ( top left hand corner of photo/oven)
Oh that one. It is the vent to the warming section of the hob, or a vent to the top under a burner. It releases steam from the oven cavity.
You could have clicked COMMENT to my last reply :>)
Sep 14, 2016 | Belling Ovens
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from forums.moneysavingexpert.com
How to Diagnose a Fault With an Electric Hob ' eSpares
www.espares.co.uk > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
Ive just got a new becko double gas cooker and everything works except for when i turn on the oven all my hobs keep clicking and sparking anybody no how to sort this out pls
Call your supplier, it may be a fault. Ket them advise you, there should be a warranty under which you can get service or support
Jun 20, 2015 | Ovens
Why is my electric cooker tripping?
there is a short in the wiring
May 15, 2014 | Kitchen Ranges
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Oct 07, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Kitchen Ranges Logo
491 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
