Yesterday my battery ran dry and the notebook shut down. It will not restart now, even with a charger battery and AC power. Do you have any suggestion?
  • 1,472 Answers
Diesha
In regards to your notebook not powering up what sounds like is happening is the system got stuck in suppend mode when the system lost power. So what you will need to do is remove the battery from the system and unplug the ac adapter from the system as well. Next hold the power button for about 10 to 15 seconds. The will clear any power the capacitors may have stored. After you have done this plug in the ac adapter only and try to power the system on. The system should boot. After it does power it down again. Next unplug the ac adapter and put the battery back in. Now you should be able to use the system normally again. Note you will need to charge the battery backup.
Let me know if you still have trouble and/or if you have any other questions.
Issken
Posted on Oct 02, 2008
My Dell Inspiron 1720 works with the battery, but shuts down when the ac is plugged in. Is there a simple fix?
Will the Notebook work with the ac plugged in and the battery out. Most of the time it will be a faulty charger or even the port the charger plugs into. The port is soldered to the main board and would be something that a repair shop would need to replace. If you search the www you can find Dell compatible power supplies for Dell at less cost than direct from Dell
Dec 12, 2010 | Dell Inspiron 1720 17" Widescreen...
Computer is frozen
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 10, 2010 | HP Pavilion DV6700T Notebook
Acer shut down
Souonds like you possibly have a bad power supply. Replace the charger and see what happens
Feb 11, 2009 | Acer Aspire 3680 Laptop
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
At Dell screen the d600 shuts off
GO INTO THE BIOS AND RESET TO DEFAULT SET UP SETTING.RICHARDM69
Dec 15, 2008 | Dell Latitude D600 Notebook
Battery and AC Charger
This could be the battery. Batteries are funny some last longer than others and some don't last long at all. This could also be the power management chip on the motherboard. This chip controls and regulates the power, it also allows the machine to switch back and forth from battery to AC, and controls the charging system. I'm leaning towards the chip, because a bad battery shouldn't cause a shut down when the charge is complete. I suggest you take it in for a professional diagnostic. They'll be able to check the power management system and tell you exactly where the problem is, and if it's a replaceable component.
Jul 16, 2008 | HP Pavilion dv9000z Notebook
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Computers & Internet Logo
David Payne
David Payne
