I want to use my hp g2 server to set up an internet radio station
  • 2 more comments
  • djesp2003 Oct 03, 2008
    yeah was helpful m8 cheers...the thing i need help with is setting up the server..i used to run shoutcast myself i know how that works.does my sever need anything...wats the bandwith how do i get that
  • djesp2003 Oct 04, 2008
    Cheerz again now it aint so much of a blur....So is there anyway i can get unlimited bandwith i see every advert for hosting my station has unlimited bandwith i thought the server had that
  • djesp2003 Oct 05, 2008
    i will b using my own server m8,i had paid for the hosting company but didnt work out....
    so i thought the unlimited bandwith came from the server..didnt realise its from my internet connection....how the helldo u get unlimited bandwith then or is that a No no lol
  • djesp2003 Oct 06, 2008
    cheerz m8 wiked help
    Problem Solver:
  • 18 Answers
Kuska is correct solution provider,you can follow it......
Posted on Aug 07, 2011
    Sergeant:
  • 268 Answers
Ah , I have been down this road myself :-) ...... I can give you a few words of advice......
  • As far as the server itsef , it really doesn't need anything spectaculer in regards to hardware & specs.....a box running XP with 512mb of RAM would suffice...so your server should be fine
  • Bandwith - you are going to need ALOT of it if you are streaming more then 64kb's....typically if you are playing any sort of music you stream at 128kb....so make sure you have a hefty data plan!
  • For the server itself , use the "Shoutcast" software for hosting the station....it is easy to use , has plenty of support and documentation....you can literally have a station up in 5 mins!
  • For broadcasting you can use the Winamp program with the "Shoutcast DSP" plugin...but if you are playing alot of music , want advertisments and like to DJ I would recommend something like "SAM 4"
Just a quick overview to get you started , all you really have to do is download the shoutcast server software , edit the config file - which includes the admin password , the port to broadcast on , the max number of listners you want etc..........
You then need to do some port forwarding, opening up the port on your router and sending the connections to your server....actually doing it is easy, but it varies by router model, you can use this site for a step by step, just select your router , and then select "Shoutcast" http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
From there you launch the server program , and connect to the server with Winamp or SAM....and now your on the air!
SHoutcast documentation to setup DJ and server:
http://shoutcast.com/download
I have alot of exp. with this , you didnt really specify a specfic problem or question , so if you need anything else be sure to leave a comment here and I can help you even more!
Posted on Oct 02, 2008
  • 1 more comment
  • Chris Callo
    Chris Callo Oct 03, 2008
    No your server really doesn't need anything but a connection to the internet.....the bandwidth is basically the data that you are uploading/downloading......most ISP's have a cap on your bandwidth , once you go over they shut you down.
    Here is a calculator to show you what I mean:
    24 kbps with 1 listeners for 1 Hour (3600 seconds).
    0.01 GB
    10.55 MB
    10800 Bytes
    That is how much bandwidth would be taken by one listener for an hour at a 24kbps stream
    To do your own calculations you can go here:http://servers.internet-radio.org.uk/too...
  • Chris Callo
    Chris Callo Oct 05, 2008
    If you pay for a hosted server from a hosting company , then yes can be unlimited bandwith and you should not have a problem. I was just going by the fact that you were using your own server , if that was the case you would be using your own bandwidth which was what I was warning you about.
  • Chris Callo
    Chris Callo Oct 06, 2008
    Its expensive to get unlimited bandwidth , but you need to call your internet provider for the details....if you need any help setting up feel free to ask!
HP Proliant ML150 G2 beep codes, 1 slow, 3 fast, then 3 fast, one slow
Google HP Smart Start. Download version needed. Unzip and burn. HP Management DVD is also available. It has Insight Manager.
Sep 13, 2012 | HP Compaq ProLiant ML150 G2 Server
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
May 18, 2012 | HP Compaq ProLiant DL380 G2 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
Hi: i have hp server ML 370 with array smart 642 controller and i replace hard drives to clean and check but when turn on the server get me many messages no scsi boot device found and next line scsi bios...
when did this beast last work.
see the manual yet>
there are many 370s ,which one, the full service tag answers that.
G , 2, on up. 9????????????
Proliant servers.
use google to find old manuals.
here is g2
https://www.manualshelf.com/manual/hp/hp-proliant-ml370-g2-server/compaq-proliant-ml370-g2-service-update.html
here is HP site covering retired products, I suspect your is..
https://www.hpe.com/h20195/v2/Library.aspx?doccompany=HPE&cc=us&lc=en&filter_status=rw#&doccompany-hpe&sortorder-csdisplayorder&teasers-off&searchword-Compaq%20ProLiant%20ML370&isRetired-false&isRHParentNode-false&titleCheck-true
HPE has the , 642 book here. (just a spec)
https://www.hpe.com/h20195/v2/GetDocument.aspx?docname=c04284123
if read that page it tells you the controller is only works with
SCSI
Compatibility with all Ultra320, Ultra3 and Ultra2 LVD family products.
it also tells you , it needs the HP utility tools to set it up properly
why would your clean disks boot? why say that?
what does this mean?
"and i replace hard drives to clean and check" surely you can elaborate the full story,
last run when?> what G number is it.
what drives , make and model. installed.
do you have the software setup seen on page 5 link just above.
quote
All Smart Array products share a common set of configuration, management and diagnostic tools,
including Array Configuration Utility, Array Diagnostic Utility (ADU), and Insight Manager.
this product is offically retired, by hp and only few books there.
but google finds many books, 15 years old now. (as old as...)
http://kmcs-service.austin.hp.com/km-ext/kmcsdirect/emr_na-c01127202-1.pdf
see this, it tells you what to do in 77 pages.
my guess is you get lost at Set the boot controller
(Chapter 4).
my guess, is that you have no HP sofware support kits.
just hardware there.... right?
next time tell the helper, full spec on 370 Gn G numer.
and full spec , on 642, version. and that you dont have the HP software kit to support this machine, it's no simple desktop, no at all.
at the least you get stuck here,
Create at least one logical drive, as described in Chapter 5.
Sep 25, 2017 | HP Compaq ProLiant ML530 Server
Why I can't boot from DVD with HP ProLiant ML150 G2 Server although can boot form CD
You must have a bootable files in a DVD where system files are usefull as bootup system.
Mar 17, 2010 | HP ProLiant ML150 G2 Server
Compaq ml 350 g2 server feature card no display
instead of using the KVM use ILO or a local keyboard monitor and mouse. Also try restarting the KVM module before powering up the server
Dec 24, 2009 | HP Compaq ProLiant ML350 G1 System Feature...
When doing new installation i can not find hand disk drives
Check your BIOS if it's detect your Hard Drive.If detected then check your system BIOS whether SATA setting is enable or not. Disable it if you have enable it in IDE configuration.If you find there is no way to configure SATA in your BIOS setting then you need to download SATA driver for that Hard drive and used a software called nlite.
Here is the link for nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
Here is the guide link for using nlite software to make a bootable OS cd with SATA driver pre-installed.
http://www.nliteos.com/guide/index.html
Here is the link for SATA driver for your ProLiant ML150 G2 Server from HP.
ftp://ftp.hp.com/pub/products/servers/supportsoftware/ZIP/HP6-port_SATA_RAID_Controller_Driver_for_Windows_v4.2.1.7365.zip
For more information on how to installed and configured check the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=435422&taskId=115
the above procedure is for Windows based Server Operating System.If you are planning for Linux based then download the drivers by selecting the operating system from the link given below
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279685&lang=en&cc=us&prodTypeId=15351&prodSeriesId=435422&taskId=135
Dec 23, 2009 | HP ProLiant ML150 G2 Server
Drivers for hp proliant dl140 g2 ..network drivers
Just go through the following link.Just select your operating system.and download the driver you want.
CLICK HERE
Thanks
Feb 27, 2009 | HP ProLiant DL140 G2 Server
HP Teaming Software
You might have forgot to configure your preffered dns servers on the lan properties, that is why you are not able to ping the other systems.
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
