Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Cleaning does a coleman propane Forced Air Heater with electronic ignition need to be cleaned or tuned-up? I not having any problem with the heater. Model: dgah056bbsa
I have a propane 5 brick heater it lights and ryns good on low when u turn it up it goes out
Posted on Dec 03, 2008
  • 306 Answers
If the unit isn't too old it doesn't need a tune up. Only thing make sure you change the filter often based on how dirty it is when you change it. say you change it every 2 months and it is filthy go to 6 weeks maybe 30 days would be good. Now if you use a Air Bear filter they last 6 months they say but depends on how dirty it is. you have a flame proving device located at the last burner in line say you have 4 burners it looks like a piece of 10 gauge wire sticking down right next to the flame it does need cleaned maybe every other year with a piece of steel wool very lightly rub the sensor to take the carbon off. It only takes few strokes to clean. And do not even get close to the hot surface igniter it is very fragile and will shatter if you even bumb it.
Posted on Nov 24, 2008
MY FURNACE MAKES A HUMMING SOUND WHEN IT COMES ON
Could be gas valve when energized
Make sure filter is clean,plugged filter will increase amp draw on MTR.
Jun 09, 2014 | Coleman Propane Forced Air Heater...
Pilot light wont stay on
clean flame sensor and it is in postion check connection if fitted , or check thermocouple , pilot could need cleaning ie too short ,
Dec 12, 2010 | Coleman Propane Forced Air Heater...
A lot of air comes out of firebox when lighting then flame goes out coleman heater
What do you have your heater hooked up to? A 20# propane cylinder? Are you using a red high pressure regulator or a silver low pressure regulator? Is this the original regulator that came with the heater? I could be a regulator pressure problem or a dirty flame sensor that simply needs to be lightly cleaned with sand paper. It's also possible your igniter is faulty or your brain box has a short. I've come across a few that just needed the brain box pushed a little in a certain direction to make good contact and work again, using a small wedge behind it. Sometimes just fiddling with it and cleaning it is all it needs. Good luck. Douglas
Oct 06, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Need to clean or replace fitler
if you have a foam typye fillter you can wash if its a cardboard base filter you need to repace
Sep 09, 2009 | Coleman Propane Forced Air Heater...
Coleman propane space heater
Google "Coleman" and go to "Propane Heaters" you should see a "contact us" or some such type in your problem along with when you bought the product they will be more than happy to help you.
Jan 29, 2009 | Coleman Propane Forced Air Heater...
Old coleman dome heater wont light
sounds like your feed tube might be partially plugged, or the orifice, you will need to disassemble the unit and clean it, normally a good dose of high pressure air will clear the tubing and orifice, check the tank too to see if you have any de-bree in it, hope that helps.
Jan 20, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
85 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
