Question about Amana Kitchen Ranges
Problem with oven door latch
After Hurricane Ike, when the electricity came back on, I noticed the oven door latch was in lock posistion and the door would not close because it would hit the door latch. I guess the door latch locked on it's own with the surge of electricity but did not lock the door in place. I have never used the self cleaning oven, so the door latch has never been used. How can I get the latch to unlock itself?
Thank You, Noahlene
  • noahsark379 Oct 03, 2008
    Hello Huuum,
    Hello Huuum,
    Thank you for the info. We tried it but it did'nt work. Thanks again, Noahlene.
  • 750 Answers
Hello noahsark,
Welcome to Fixya
You said, after Hurricane Ike, when the electricity came back on, you noticed the oven door latch was in lock position and the door would not close because it would hit the door latch. You guess the door latch locked on it's own with the surge of electricity but did not lock the door in place. And that you have never used the self cleaning oven, so the door latch has never been used. How can I get the latch to unlock itself?
Was the range get under water?
If so there may be some shorts in it or faulty electronic parts!
Try turning the range off and then turning the power off at the breaker for 5 minutes.
This is should reset the system in an electronic range.
If it works , great .
If not you may need service to diagnose your electronic problem.
Let me know that it works!!!!!
Send me the Brand and mode;l number.
Please remember to leave a rating when you finish.
Huuum
Posted on Oct 03, 2008
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
Admiral electric range with self cleaning oven
Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
Jan 29, 2008 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
DOOR LATCH IN LOCKED POSTION WON'T RELEASE
try to press and hold the clear off key for three to five seconds.you may need to remove the back panel and remove the door lock mechanism in order to release the lock try unplugginf the unit for a couple of minutes as well
Jun 22, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven door lock does not unlock, I turned on the self clean mode and then changed my mind and turn it back off about 3 minutes later. But it does not unlock. The lock light is blinking.
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 26, 2009 | Electrolux E30DF74PS Dual Fuel (Electric...
Trying to find out how to lock the door on the whirlpool designer
The door latch mechanism is defective. It is self-latching.
The door latch switch must be replaced.
Feb 21, 2009 | Whirlpool RBS275PD Electric Single Oven
Older Kenmore oven- door locked by itself
wanna say you have a faulty latch/self clean assy. however the erc( lcdd panel could also send eratic power supply to latch mechanism)
Mar 09, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
253 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
