Question about E-Machines eMachines Desktop PC
Screen has bluish hue to it
My computer works fine, but all of a sudden my screen's color is all jacked up. It's bluish/turqoise instead of the normal color.
    Problem Solver:
  • 10 Answers
Or you could move your Stereo speakers away from the monitor.
Posted on Oct 04, 2008
  • 4,889 Answers
I had a similar isue with my monitor sometime back and it is due to some loose solder on the monitor's inverter board. This is a very simple repair and you can do it yourself if you are good at electronics. I could locate it pretty easily by checking for continuity. Otherwise leave it to a tech it wont cost you much anyway..
Posted on Oct 03, 2008
  • 68 Answers
Check monitor cable to back of pc if loose you can lose a primary colour. also if your pc has seperate video card can be loose reseat in slot.
Posted on Oct 02, 2008
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
My background on my screen recently developed a purple hue to it, instead of a white. Can this be corrected?
This is likley a problem with the monitor's signal cable. Try moving the cable around steadily and see if the color suddenly goes back to normal or changes to a yellow hue. If this is the case and you are able to remove both ends of the cable then a replacement can easily be purchased from a local computer store or online. (Try or
Mar 17, 2011 | IBM ThinkVision L170 17" LCD Monitor
Photosmart A512v: colors are not true, more it the ink cartridge that needs replacing or is it the paper????
In the setup menus, try changing the ambient lighting from flourescent to incandescent or daylight. This is the most comon culprit when pictures have a definite bluish hue to them.
Aug 18, 2010 | HP Cameras
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Monitor has turned turqoise instead of normal color! Why and how do I fix this?
If you are talking of a CRT monitor, the problem is likely a dead cathodic gun. Warning! there are charges of several thousand volts inside the case. DO NOT disassemble without knowledge. If it is not worthy to pay a technician, please dispose at an Eco-Center and not with the house trash. Electronic components include lots of heavy metals which eventually leach.
You should try tweaking the settings suggested by the manufacturer and adjust the colors
Oct 14, 2009 | Gateway FPD1975W 19" LCD Monitor
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Bluish greenish screen
Happened to my tv. Sign of tv or monitor going bad.
May 27, 2009 | HP Computers & Internet
Cant figure out color issue with computer.'s a Dell and even when it's's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
White looks blue
usually there's a HUE setting for color problems. try to go and play with the HUE whih is usually beside the contrast, brightness....etc.
if that didnt work, then there's a problem with the deflection coils focusing, either from shipping or a hard hit. if its still under warranty send it back for repair.
let me know if that helped, good luck :)
Jan 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
A blue hue
If color correcting does not fix the problem you will probably need some professional equipment in order to fix it. It would probably be best to contact a professional service provider.
Feb 23, 2006 | Sony VPL PX20 Multimedia Projector
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
