Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire Gallery I just want to know how to obtain a manual for the following: Frigidaire Gallery Model #FRT22RGCD1 Serial #LA52500219
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
Posted on May 22, 2008
peyton32034
  • 410 Answers
SOURCE: serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Posted on Jan 27, 2009
  • 65 Answers
SOURCE: How replace frigidaire gallery freezer
This is simple just pull it out. The door gasket is a push in meaning it has a channel that it is pushed into and to remove just hold the door firmly with one hand and pull the gasket with the other. It will peel right out of the channel and then just press the new gasket back into the channel. Hopefully you will find this to be easy enough once you have tried it seeing as how you dont even need tools to replace this kind of gasket.
Posted on May 03, 2011
Testimonial: "It was so easy to replace that it is embarrasing. Thank you"
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Where is vent fan on fridgidaire gallery disherwasher
Hello - I am happy to assist you. First, I will need your model (and serial number if you have it) to better address the issue at hand. Thank you.
Jan 23, 2013 | Frigidaire Gallery FGBD2451K Full Console...
I have a frigidaire gallery stove.I need a temperature sensor . Model No. PFEF385JFT3.Serial No.NF82105720.Where can I get one.How much is it?I believe this stove was puchased in Canada.
According to the Frigidaire website the place in Canada where parts can be obtained from is
Frigidiare Parts& Service
7075 Ordan Dr.
Mississauga,Onterio L5T 1K6
Tel# 905-565-9200
GENE
Sep 22, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Where do you find the model and serial number on a free standing frid. range. i see a sticker on the back with the following number but nothing else. 316232611
Hi, welcome to Fixya. If it is indeed a freestanding range... The model & serial identification label should be at the bottom left or right side of the frame when you pull out the ultitity drawer. Let me know what you find. Thanks for visiting "fixya" today. Please rate this solution positively if it indeed was helpful...but if not helpful let me know. Thanks and good luck. Macmarkus :)
Jul 01, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Serial number
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
