Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
The chain on this Poulan tightens to the point that the chain will no longer spin on the bar after chain adjustments
  • 3 more comments
  • olm911 Mar 19, 2009
    I have run a chainsaw professionaly for many years and this is the first time I have had this problem. I know that the chain on a chainsaw will loosen up when it gets warm but the one on my saw gets tighter and tighter untill the engine will not spin the chain. I start by adjusting the chain properly before running the saw. after using the saw for about five minutes it acts like it is loosing power. I shut it off and check chain tension and it is too tight. I loosen it back to the correct tension and run it about another five minutes and then same thing. I am stumped. Good chain, Good tensioner, Good bar, Chainsaw is not equipped with a chain brake. some one please help me figure this out.
  • Anonymous Mar 13, 2014
    The chain wont stop spinning
  • Anonymous Mar 14, 2014
    to adjust chain on gardentec petrol chainsaw how tight should it be
  • Anonymous Mar 16, 2014
    boltless chain tensioner on 2245 after tightening chain still loosens
  • Anonymous Mar 22, 2014
    having problems tightening blade to where it remains tight, have read the manual but it will not stay tight? suggestions???
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
Adjusting an electric chainsaw bar and chain
UN PLUG FIRST THEN Loosen the bar and lift with the chain then tighten with a screwdriver the screw is normally found at the front beside the bar re tighten the bar the chain should not be over tight check chain oil
Jul 17, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
How to tighten chain
Srew under blade and chaine. Make sure the tightner is align with is slot. Then secure cap with the two bolt lightly fist. Then srew the flat srew until chain is tight. Just enought that you can move the chain by hand. Then tighten the bolt (Nice snug fit) Please do not use impact.
May 24, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Chain wont tighten Large Knob will not turn.
Try loosening the nuts that hold the cover to the blade slightly. This will allow the chain tensioner to move to the proper tension. Then retighten the nuts to their original tightness.
Aug 20, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I can't keep the chain tight on the chainsaw
After adjusting make sure to tighten the bar bolts(nuts). If they're missing, replace them and tighten securely after adjusting the chain tension.
Jun 27, 2011 | Poulan ES350 16" Chain Saw
Chain is extremely loose and turning the screw to tighen does not fix the problem
You need to loosen the cover fasteners before the adjuster will do anything. Turn the adjuster CW to tighten the chain--bring the chain up to the bar, but not so tight that you can't move the chain by hand. Recheck the tension after tightening the cover fasteners. Hope this helps!
May 21, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
The chain has come off of my 14'' poulan gas chainsaw and I can't get it back on?
Release chain tension. Loosen nut on bar, re-install chain, check for chain not binding when moved by hand, but snug on bar, tighten and you should be back in business.
Aug 28, 2009 | Poulan Garden
I have an 18'' Poulan chain saw that won't start.
Take the wire of the spark plug,and see if it shocks you when the cord is pulled.If not there may be something wrong with your coil.(loose wire for example)If it does shock you,you may want to check out your piston rings,or the little air/fuel mixture valve between your carburetor,and cylinder.
Jun 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I am having a problem with the chain on my poulan chainsaw. the chain comes loose or comes off after just a few cuts. am i missing something or could it be a malfunction
It sounds like the chain is not being set quite tight enough. Turn the tightening screw until the chain barely lifts above the bar when pulling on the middle of the chain.
May 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
975 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
