HITACHI CMPAD14D 42 in plasma it has a black strip some 3 inches wide runing near the middle of the tv from top to bottom and it some time comes on then dissapears and so on and so forth
HITACHI CMPAD14D 42 nel plasma ha una striscia nera di circa 3 centimetri runing ampio vicino al centro della tv da cima a fondo e che da qualche tempo si accende poi scompare
Posted on Mar 21, 2011
On my Hitachi 50UX26B the only button that is working is the power. Neither the remote or the buttons on the TV will change channels or volume. Today it also has a wide black strip in the middle, about 24...
you likely had a power outage, unplug set for at least ten minutes and put power back to it.
Seen this in a lot of these sets and owned two of them myself.
before you rate this solution if you have a question let me know.
Unplugging set and plugging back allows the microprocessor in the set to reset
SD TECH
Jun 23, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi digital ultravision 50"
Hello bugster421,
Can you post a picture of this problem? It will go a long way in determining what is happening.
Thank you,
Shuttle83
Oct 26, 2007 | Sony KP-46WT500 46" Rear Projection...
Black line on hitachi projection tv
sounds like the water has went under the rim and dried there the line will never disapear
Jul 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
I need to remove screen protector on my hitachi 65" big screen tv
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).
Once this strip is removed, you should be able to see a gap (~2mm) between the top of the protector and the frame. Pull the middle of the protector toward you (you may need to hook it with something like a chrochet hook to get it out to where you can get a finger on it). Pull out one side of the protector, then work it loose fromt he bottom. (If it is stubborn, you may have to loosen the bottom frame. Take of the speaker grill, then unscrew the screw on the bottom of the surround for the control panel and pop the surround out. Then there are 3 screws that hold the cabinet frame {might me different for the 58B} and beneath that, 3 screws that hold the bottom of the inside frame. Once those are removed, you should be able to flex the inside frame enough to loosen the protector.)
Installation is the reverse. There are two grooves (at least on my set), and the protector goes in the rear groove(!) (same as the screen itself - first time I tried to put it in the unused groove closer to the front of the screen, and that iddn't work). The black plastic retainer strip goes in the front groove.
Jul 18, 2009 | Hitachi 43F300 43" Rear Projection...
Verticle black bars
Check the connections on the flat cables to the screen. Be sure first to disconnect the power supply from the x and y sustain boards before you disconnect any of the flat cables.you will burn the cables from the stored energy in the power supply, also check cables on c boards at bottom of screen. If this does not fix probably bad panel.
Apr 24, 2009 | Televison & Video
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
Removing a screen protector from a Hitachi 50UX58B Projection color TV
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).ea84b4b.jpg
Mar 22, 2008 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
