Intuit QuickBooks Premier 2004 for PC Logo
Posted on Oct 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO UNDO MY LAST BANK RECONCILIATON?
DID THE BANK RECONC. OF SEPTEMBER /08 I NEED TO UNDO IT
BECAUSE I DID A JOURNAL ENTRY WITH TOO MUCH ZEROS.
Scott Fair
Level 2:
Champion:
  • Intuit Expert 237 Answers
  • Posted on Oct 18, 2008
Scott Fair
Intuit Expert
Level 2:
Champion:
Answers
237
Questions
0
Helped
99038
Points
281
You actually have 2 options
You can edit the Journal Entry to change the amounts.
Or
To unreconcile, you must enter the register for that account, go to the box that has the cleared checkmark, and click on the checkmark until the box is blank. This has to be done on each transaction for the reconcile.
Once that is completed, you can reconcile that month again.
Economics: What is easy way to record transaction?
A journal
Recording accounting transactions
  1. Journal entries. The most basic method used to record a transaction is the journal entry, where the accountant manually enters the account numbers and debits and credits for each individual transaction. ...
  2. Receipt of supplier invoices. ...
  3. Issuance of supplier invoice. ...
  4. Issuance of supplier payments. ...
  5. Issuance of paychecks.
Dec. 18, 2020
Recording accounting transactions - AccountingTools
Has a payment been made to Ribbons Tanka Journal probably last May
not a question for this site
ask your bank or check your financial records
1helpful
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
HOW TO POST PAST YEAR ENTRIES INTO MYOB
You would have to post the entry as last financial year, just to keep it all ligit. After you have done so check that your retained years earnings are correct!.
Answer to puzzle 121
Climb up the stairs on the left(have to solve puzzle 100 first)
Climb up to the exit on the right
On the roof top knock on the door
Continue into the house
Mystery solved Noise at the manor
Touch the painting on the right of Flora's neck
Mystery solved The Golden Apple
Journal Entry The Real Golden Apple
Journal Entry The Fortunes Location
Watch the credits
JonnieC
1helpful
2answers
Peachtree first accounting 2007 income statement has incorrect %
Wow, that's a lotta percent... something is posting incorrectly, and could be for one of two reasons:
1. You could go to Tasks > Maintain > Company and go through the way the company's accounting is set up, but more than likely, it's #2.
2. Someone is posting journal entries and getting their debits & credits mixed up. That's something that unfortunately nobody can help you with unless they're physically there with you going over individual journal entries. I would suggest this: If there was a time EVER when the income statement was correct, GO BACK TO THAT. Then start printing journal entries from that point forward and make sure that all the amounts for each journal entry were correctly categorized as either a debit or a credit. All journal entries must zero out at the bottom. I don't think that Peachtree will even let you save a journal entry unless it's zeroed out. Good luck!!
Error Code 406
"XMT/RCV password does not match. Last 4 digits of TSI does not match with the last 4 digits of the ONE TOUCH, ABBR Telephone number." This is straight from the Panasonic service manual. I would suggest looking in the User's manual uner "passwords" and try to either reset or clear out the password info.
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
