Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer wont start
Dryer will not start when switch is turned
Dryer won't start when button pushed, slight buzz sound.
Open door and spin drum to left then right.
Posted on Oct 26, 2008
  • Dess Jan 08, 2013
    I had read everywhere that the motor had failed and thought I would have to call a technician with its $$$! Then I saw this post and did what it suggested; manually spun the drum a bit to the left and a bit to the right and then the dryer started like a charm!
  • 943 Answers
Hi. thanks for the question . if you have a buzz sound when you try to start .the motor has failed .thanks the appliance doc
Posted on Oct 03, 2008
Dryer buzzes but won't start
see the diagram :
1) O.k if the thermostat 2) Thermofuse is o.k is good resultant BUT please 3) Test the door switch for open or defective , if the remain open the motor will NOT START. see the diagram. 4) After changing the switch if the problem remain the same the motor is faulty( centrifugal swithc, etc) need repair or replace. 5) Test the push button start for diryt or open, test the wires for loose, broke, or burn wires too.
God bless you
Jun 09, 2012 | Whirlpool LER4634J Electric Dryer
MAY MAYTAG DRYER WONT START I HAVE POWER WHEN I PRESS THE START BUTTON IT SOUND LIKE IT SHORTED OUT
HI
Need to know what the unit does, Buzz, nothing? Because if it buzzes it could be a clogged blower or bad motor, its important to know this information.
Please get back to me
Sep 08, 2011 | Maytag PYE2300AY Electric Dryer
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
The buzzing is a good sign that the motor is bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Maytag MDE9700AYM Electric Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Dryer wont start
motor might be dead repl/.
Jan 03, 2009 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
255 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
