Question about Brother HL-2070N Laser Printer
Paper jams, white streaks
I keep getting paper jams in the back portion of my Brother. I can't find any foreign material inside. And now my printed pages have white "streaks" where there is no printing.
  • marge383 Nov 19, 2008
    Hamedo,
    Thank you for the suggestion. Unfortunately I can't try it because we have already replaced the printer.
    Best Regards,
    Marge
  • 57 Answers
Hi marge383
this problem occures from the sensor found in the outgoing of the paper just before the fuser, if you are not technition check all sensors.
hope this helpful for you,
thanks
Hamedo
Posted on Nov 19, 2008
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Paper jam
Hi Ruth,
This should help you fix the issue.
Remove Jammed Paper
If business card sized paper loaded sideways is jammed:
1. Power the printer off.
2. Open the top cover.
3. Remove the jammed paper with your hands.
Note: Be careful not dirty your hands. Do not use tweezers or other metal instruments to remove the jammed paper or printer damage may occur.
4. Close the top cover and power on the printer
5. Load the papr correctly in portrait orientation to resume printing.
remove foreign objects
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once.
The images below show the iP2200 model.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
Note: Avoid touching inner parts.
4. Power the printer on and confirm that the printer operate normally.
Use a flashlight to find any possible jam.
Regards,Suhail
May 19, 2012 | Canon iP2600 series
Mfc240 c gives unable to print see troubleshooting guide 51 I have tried all I know to do
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Aug 13, 2011 | Brother Office Equipment & Supplies
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
Canon mp470 keeps telling me there is a paper jam
Hello my friend,first thing we are going to check is if its a jam inside from a foreign object.So
  3. Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer.
  4. Close the scanning unit (printer cover).
  5. Power the printer on and confirm that the printer operates normally.
But in this procedure be very careful and don't push hard anything!
Jan 31, 2010 | Canon PIXMA MP470 All-in-One Printer
The printer started jamming and shreading up paper. Now the paper is being pulled through at an angle if at all. When there is no paper going through the printer still seems to be going through the...
The following a step by step instructions for the printer issue:
First Set Prevent paper abrasion (Windows)
By using the Prevent paper abrasion function, the space between the print head and paper is increased, preventing print head contact with the paper.
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer maybe damaged. If there is any foreign material, remove it at once.
Removing paper jam:
If the paper tears and a piece remains inside the printer, open the Top Cover and remove it. If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically.
Paper Loaded in the Cassette Jams inside the Printer
(1) Press the POWER button of the printer to turn off the power. Then, open the Rear Cover.
(2) Fold a piece of A4 or Letter-sized plain paper in four, push it in until it hits the jammed paper, then pull out the paper folded in four.
(3) Close the Rear Cover, then press the POWER button of the printer to turn on the power.
Wait until the jammed paper is automatically ejected.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Sep 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Pixma iP 1500 shows paper jam and makes squealing noise when activated to print. There was no paper jam when this occured.
Remove foreign objects from the paper path iP1500
Remove foreign objects Foreign material inside the printer can cause printer malfunction Caution: The power cable should be disconnected from the unit when inspecting the paper path for obstructions.
  1. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove it by hand, or with tweezers.
  2. Check to be sure that there is no foreign material by opening the printer's top cover and paper output tray.
Sep 05, 2008 | Office Equipment & Supplies
Unable to print
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset.
See page 123 of the manual for more. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Sep 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
DCP 115C does not print
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Check Paper
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Feb 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother HL-2070N Laser Printer Logo
150 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
