Question about Graco ComfortSport 8431
Car seat straps
I have a Graco carseat and when i tighten the shoulder straps the left strap is tighter than the right, causing the harness to not fit properly. How do i readjust this? Please help this is driving us crazy!
  • april1978 Mar 02, 2009
    I have the same problem with my Graco Comfortsport model # 1747504
I have the same problem with mine. It's an easy fix. Unlock the straps (pull the little gray release tab) and then pull firmly upward on the lap belt opposite the loose strap. To reword: If your left shoulder strap is the loose one, go the right side of the seat, where the LAP belt comes out of the seat, and pull firmly upward on that part of the belt. It will pull the slack out from the other side. I hope that was helpful.
Posted on Apr 13, 2009
How can i make the headress go upto make the carseat bigger??
Good Evening
Take hold of the headrest and lean it forward (toward the front of the carseat) then you can slide it up and down to wherever the harness needs to be for the best fit for your child.
The shoulder straps should be no more than 1 inch above or below the childs shoulders when correctly adjusted.
Jan 04, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
I took off the cover to wash and now I'm trying to figure out how to get straps put back on
This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
1st pull through the belt adjusting piece through the bottom cover ****.
2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
Oct 26, 2009 | Graco Snugride
I have a Cosco Juvenile car seat and my husbands car. In the back seat he has seat belts that are a combination shoulder and lap strap. How do you connect the car seat so that it is secure in the back...
you take the seat belt and put the lap strap thru the back of the carseat and click in in on the oher side pull tight and carseat is secure. the shoulder strap part doesnt effect the safety of the car seat at all
Sep 12, 2009 | Baby Gear
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Shoulder straps
There should be metal hooks on the backside that hook onto the loops at the end of the shoulder straps. They will definately be metal so should be easy to spot against the plastic back of the car seat. They usually are sort of rectangular and have one side that has a 'lip' so the straps aren't supposed to just slip off. (Though I can imagine the possiblity of this when the belt is not stretched as it is during use) Refer to your manual if you cannot find them. If you no longer have the manual, you should be able to locate one for downloading or viewing PDF file at the manufacturers website. Hope this helps! :)
Jul 25, 2008 | Graco ComfortSport 8431
Manual for a car seat
First set the harness together at the chest clip and the **** buckle. Then slide each shoulder strap through at the best height for your child. For a forward facing seat , it should be at or above the shoulders. Once both shoulders are passed through, there is a Tshapped metal flat piece, each belt slides onto that. That is 2 of the 4 ends of the straps squared away. The bottom 2 , you slide through the holes in the car seat, through the holes in the shell of the seat, and then pull to ensure they are in tight. Thank you!
Jun 15, 2008 | Graco Baby Gear
Harness is broken
Most likely Graco will send you the replacement parts free of charge:)
Apr 02, 2007 | Graco ComfortSport 8639 - Grey
Graco ComfortSport 8431 Logo
295 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
