Question about Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold electric range.
When turning on the self clean option, after 1 minute, I get E 1 F5 on the dispaly panel. What do I do?
  • 750 Answers
Hello delmonico
Welcome to Fixya,
You said, when turning on the self clean option, after 1 minute, I get E 1 F5 on the display panel. What do I do?
Try this .
Turning off the power to the range at the breaker for 5 minutes and see if this will reset the system.
Display shows messages
Is the display showing a letter followed by a number?
Depending on your model, press OFF/CANCEL or CANCEL/
OFF to clear the display. See “Control Display” in the
“Electronic Oven Controls” section. If it reappears, call for
service.
Let me know how it goes.
Thank You,Huuum
Please remember to enter a rating!
Posted on Oct 03, 2008
I have a electric whirlpool self cleaning oven, after the cleaning process the door is still locked. It's beeping and error message E1 F5
Assuming the door is still locked after cooling, then either the door switch is bad or the wiring from the control panel to the door switch has a problem. First disconnect the power from the oven. Then check the wiring and connectors (from the control to the switch and back). If those are fine, you need to replace the door switch. After replacing the switch or fixing any bad wiring/connections, reconnect the oven to power. Press and hold any key on the panel for at least one minute to clear the error. You should see F2 on the LCD panel. Press Cancel to clear the error then check to see if any new error (or the old one) message occurs. (Usually a new error message will come up within a minute.)
Which model Whirlpool oven do you have? If you add a comment with the model number, I may be able to provide a parts list and diagram of the unit.
I hope this helps.
Nov 22, 2011 | Whirlpool Kitchen Ranges
When I go to self clean the oven a code F5 E2 comes up and it will not clean.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Mar 14, 2011 | Whirlpool Accubake RF362LXTS Electric...
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Self cleaning keeps popping up beeping with F5
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Jun 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I am trying to self clean my Whirlpool stove/oven. I keep getting E1-f5 on the control panel. HELP, my oven is dirty~
use easy offoven cleaner. when using the self clean feature the oven gets so hot that it's likely to burn out some of the electrical components
May 20, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Model number RF378 LXK turned on self clean oven
The oven door latch system has a fault in it.
You will need to replace the door latch motorized mechanism.
Dec 20, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Whirlpool GR465LXLS Electric Kitchen Range Logo
235 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
