I suggest you don't just reset the code(s). This may be a source for greater problems. The good procedure would be to retrieve the code and fix the problem. Then the code(s) can be cleared using the same instrument and procedure that retrieved it or them.
Need to be more specific reset what codes and what do u mean by OBD it is a system not a tool u may be able to reset codes by unhooking negative battery terminal but most car will reset themselves after so many ignition cycles without seeing the problem
If you forget the phone security password then try default code like 0000 or 1234 to reset it .If it doesn't reset your mobile then visit Unlock Free com here they provide master reset code for your Nokia 1100 phone at free of cost. using this code you can reset your mobile and again set a new password.
A generic code reader at a auto parts store should reset the codes for you,auto zone might do it for free,if not the code reader is only about 70 bucks.
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
You can also try disconnecting the battery. That will reset the engine check light until the problem occurs again. It may not clear stored diagnostic codes. Make sure that you have the stereo anti theft code if needed.
Yes, it should be reset. Auto Zone usually offers to reset the code on something like that if you buy the part there. You can reset the code yourself. Remove the Negative battery terminal for 1 min and then reconnect it. That should reset the fault codes in the ECM.
