Question about Pyle PLDVIN7 Car DVD Player
My sound from the speakers
I just bought the stereo used and i installed it in to my 92 ford ranger. the screen stereo comes on and the screen goes in and out but i cannot get any sound to come from the speakers. i double checked the wiring and i even straight wired the speakers to the radio and still no sound. does anyone have any idea what it could be?
  • 3 Answers
If you have just one shorted out speaker it will cause all the speakers to have no sound. Try disconnecting one speaker at a time.
Posted on Aug 08, 2009
Show me wire diagram for 92 ford ranger battrey termials
Red cable goes to the + terminal of the battery. The black cable goes to the - termonal of the battery.
Feb 08, 2015 | 1992 Ford Ranger
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
I have a 92 marquis, and ive just changed out the factory stereo with a aftermarket. How can i hookup the amp that came with the bose system??
If you bought a wiring adapter kit for the aftermarket stereo, the unit should hook up directly to the stock bose system. Note: If there is sound coming from the speakers after installation, the amp IS hooked up...the speaker wiring is routed to the factory amplifier, not the stereo itself, the stereo wiring is just signal leads to the amplifier. In some instances, you may have to connect the amp remote wire to the remote wire coming from the aftermarket stereo(blue wire). I hope this helps. Any other questions, just reply.
Feb 06, 2011 | 1992 Mercury Grand Marquis
How do i wire a cd deck to a 92 Ford Ranger
Your best bet is to get a radio installation kit for your year truck. It will have a harness to connect the new stereo to and plug into the original radio harness from the truck.
Mar 16, 2010 | 1992 Ford Ranger
Factory stereo wiring
Right here!
1986 Ford Ranger Car Radio Wiring Chart
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Corners
Mar 04, 2010 | 1986 Ford Ranger 2WD
I need wire color codes for a 2009 Ford ranger basic radio. Installing an aftermarket stereo.
I took my time to find this for u please show your thanks with a "FIXYA" rating.
2009 Ford Ranger Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Violet/Red
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: Blue/White
Car Stereo Dimmer Wire: Green/Red
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): White/Orange
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Sep 30, 2009 | 2008 Ford Ranger 2WD
DAUGHTERS 1998 FORD ESCORT STEREO WON'T PLAY?
On some wiring systems you have to make sure the wires are not touching neg. and pos.just try some speakers without actually installing them. make sure mute button is not on.
Oct 25, 2008 | 1998 Ford Escort
Need wiring diagram for 1997 ranger stereo
1997 Ford Ranger Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Purple
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jul 31, 2008 | 1986 Ford Ranger 2WD
Pyle PLDVIN7 Car DVD Player Logo
319 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
