Question about Pioneer PRO-520HD 53" Rear Projection Television
Pioneer tv i have a old pioneer projection tv that will turn on and about 5 seconds later turn right back off
  • 149 Answers
You may have problem with convergence IC is shorted and goes in protec mode
Posted on Oct 17, 2008
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
I go to turn it on and it sizzles and shuts itself off.
Replace the flyback. You need the 259296 flyback replacement kit which has the flyback related capacitors and the CD with detailed instructions. The kit is available at www.tvrepairworld.com
Sep 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
SD533HD% Rear Projection TV wont turn on
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
BUT DON'T DELAY AS SOONER LATER TV WILL NOT RESTART..
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Dec 28, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P4683
Good luck.
cell
Oct 15, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
TV shuts off seconds after being turned on
This is actually a common problem with this unit and one that Pioneer is aware of... Over time the feed resistors in the convergence circuit change in value and the convergence ICs begin to fail, placing more of a load on the power supply than necessary and stressing components in the SMPS. The fix; Pioneer recommends upgrading the convergence IC's from STK392-110 to STK392-180, change all resistors in the convergence circuit that have changed in value and replace the power supply to repair the unit.
Jun 27, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
TV turns on then right back off
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Very possibly an electrolytic capacitor gone bad. You'll need to work on that, and then readjust the set. Not a major repair. good luck
Mar 15, 2006 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer PRO-520HD 53" Rear Projection Television Logo
198 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
