Question about Hoover U6476-900 WindTunnel Vacuum
Motor replacement on U6476-900
Any tips on how to get to the motor? Is there at least a parts diagram available?
I need a parts diagram of a dyson dc 18 that I can read. Please help.
Sorry we do not have this diagram. Contact Dyson, whom I suspect is not going to be very helpful based on previous experiences
Oct 11, 2012 | Dyson Dc-18 "slim" Upright Model...
Brush roller wont turn, motor is good and the curcuit board appears fine. No evidence of anything blown or broken wires either.
Judging from this parts diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Dyson-Inc-Parts/Vacuum-Parts/Model-DC15BALL/3207/0645000/50026393/00001?blt=06&prst=&shdMod=
The brus motor has what appears to be a transmission on it.
If you have it apart apply power and make sure the shaft that fits brush is turning.
If the motor spins but the shaft does not you need to replace the motor asm
If the shaft spins the problem is with the brush or the way the shaft attaches to the brush
May 21, 2011 | Dyson DC15 Animal Bagless Upright Cyclonic...
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
Hoover steam vac F7427-900, brushes stopped
Yes, But very carefully. I have cleaned and replaced the bearings on many of these items. I found the bearing to be available online. There is also a measure of prevention to install a new gasket when re-installing the turbine.
There are 6 screws under the bottom to remove the hood and nozzle. two snaps on top at the back to release.
Two long screws under the botton center for the turbine and 2 more short ones on top at the nozzle body. disconnect the hoses and remove trubine. If you need more assistance please reply to this post.
Apr 11, 2010 | Vacuums
I have a kenmore canister model number 116.2645083 I need a replacement motor. I was given 2 different numbers: 1. 4147248 2. AC92FAUX200 I can find the 2nd motor, but it doesnt have the 4 wires like the...
Greetings from GoVcauum.com,
Ok, so good news, I have looked up your model number for your Kenmore vacuum and found that your Kenhmore canister takes the motor AC92FAUX2000.
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357In stock
You may buy this part from the link to GoVacuum.com above. I have personally gone back and checked this motor, and it does have 4 wires that come off the motor itself.
I also verified this by pulling up your parts diagram for your model, and it did call this part number as well.
We offer the best return policy in the industry. We give you 60 days to return any product purchased from GoVacuum. We will even include a return label with every order, and if for any reason the motor doesn't fit, send it back with the free return label, and we give you a full 100 Refund, no restocking fees.
Please feel free to call me or email me if you have any further questions.
Chris Jones
GoVacuum.com
1-866-468-2288
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Oct 24, 2009 | Dyson DC14 All floors Bagless Upright...
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Trigger not working
Sounds like you need to replace the handle valve pieces, if they are available, if not then you will have to replace the hose asm. Just take the valve off and see if one of the pieces have a piece broken off. Then with your model number, you can see if that piece is available from someone that has Hoover parts.
Jan 07, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover U6476-900 WindTunnel Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
