Question about Avaya Lands Phones
Are we able to have the Fax line and voice on one line without a fax switch? Thank You
Yes. But it depends on the phone system you have.
What system do you have?
Posted on Oct 04, 2008
Problem with the F/T setting.
leave these phones unused for one day and then use it and see.
leaving them unused will make everything get settled.
Jul 29, 2008 | Office Equipment & Supplies
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Cant receive a fax
Your voice mail is probably answering before the fax can grab the line. Try setting the number of "rings to answer" on the fax to 1 or 2 rings less. The best solution if you only have one phone line is to buy a device called a "comswitch". I use one. They automatically detect if the incoming call is a fax and switch the call to the fax machine. If its not a fax it switches the call to the proper device. They are not that expense. Look on e-bay.
Larry
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Receiving Fax using a phone line with voicemail on a Lexmark 5470
well, your voicemail can configure to key tone?? or have some one configuring options????
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Same Number for Fax and Telephone
The fax is designed for use with an answering machine, the greeting for which must be no longer than 15 seconds. If voice mail in this case is referring to answering machine, be certain that the message is as indicated.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Mar 29, 2008 | Canon FAX-JX200
Lands Phones Logo
Top Avaya Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
