Question about Maytag MAH6700AWW Neptune Front-Load Washer
Suds Error I have had a maytag neptune front end loader for 3 yrs. paid 1000.00 for it. It started with a suds error about a year ago and my husband found where it was stopped up. He fixed that and it worked for about 6 months. Now it has gotten so bad it takes 2 hrs. to wash 1 load of clothes. It will not rinse and spin the clothes at all and if you use the rinse and spin cycle it still want. It does not get the soap out of clothes either. I am using the HE detergent and about a tablespoon full. Even if I don't wash big loads it still does this. I am sick of it and I need somebody to help me. I have even taken it to a repairman and he didn't know where to start! I am ready to take a hammer to it. This is my second maytag and I will never have another and I would not recommend this machine to anyone.
  • johnl1990
    johnl1990 May 22, 2012
    may tag is nothing but a bunch of **** we pay thousand for there **** they must have ******* Mexicans working for them who cant read or write thats why the ******* machine isnt working
    Novelist:
    Champion:
  • 261 Answers
Ok lets check some stuff. I don't like preaching about drains but this is where I start. With these Maytags it is harder but you need to pull that hose out and make sure it doesn't rest in water. Two in the past when your best man cleaned the machine out did he find alot of lint? If so reduce the cycle by choosing less than normal soil. We need to remember Maytag has put a restrictor in there pumps because of overflows at the drain so we must check often on this item. Another item that is bugging me is your timer, have you noticed a loud buzzing sound during operation from the timer or does it seem the machine is not spinning the way it should? Maytags are known for a good spin, let me check on recalls, drop me a note if you find anything new.
Posted on Oct 15, 2008
  • Sgawebb Dec 31, 2011
    I too would never recommend a maytag to anyone. I've had the suds error and a 3 E error. It takes over 3 hours to wash a load of v
    Clothes. I paid thousands for this washing machine and dryer and no one knows what to do. Some have said replace the mother board whatever that is. I just know that this washer should never do this. I also just found out it was recalled! Model MAH8700WW. SERIAL 12020517GV. PLEASE HELP! I don't have the money to replace this thing!
How can you reset the suds error code message on a may tag Neptune washer?
Try running a load without adding anymore additional soap and see if you can get it to go through the cycle, you may have to try it several times. I would also suggest cutting the amount of soap down to help prevent this in the future.
Jun 23, 2015 | Maytag MAH6700AWW Neptune Front-Load...
It's showing the code "SudS" where the minutes
Hi
When washer detects suds then this error appears. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Suds error
http://www.servicematters.com/maytag_library/docs/16025909.pdf
Here is the service manual for your machine.
When you get the suds cleared out you must use H E soap and or less soap.
You may need to run 3 or 4 cycles with no clothes at all to clear out the existing suds.
Mar 11, 2010 | Maytag Neptune MAH9700 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load whasher MAH8700AWW Error/Information code OE is showing and does not show up in owners manual. What does this mean
my maytag mag8700 (4 yrs old) has begun to shake so bad itt walks 4" to the wall. it did not do this before. i regularly get SUDS code. i did run afresh through 3x's. 2 weeks later i have SUDS code again HEPL!
Mar 23, 2008 | Washing Machines
SUDS error code
I suggest you disconnect the tube from the water level control pressure switch and blow it out well. Then, if need be, disconnect the drain hose and make sure it is clean as well.
Mar 13, 2008 | Maytag Neptune MAH9700 Front Load Washer
Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Nov 14, 2007 | Maytag Neptune MAH6700A Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
99 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
