Question about Sony PS-LX350H Turntable
50Hz noise appears at the end of the disc
When the tone arm gets towards the end of the disc, there is a loud 50Hz hum coming through the amp & speakers. At the begining of the disc everything is quiet. Everything is earthed correctly and this problem started one day quite suddenly. Sony dealer says this is too old to be economically repaired; anybody got any good ideas? The deck is only a few years old.
  • timmyketeer May 11, 2010
    What brand of cartridge are you using?
  • Sony Master
  • 5,568 Answers
Because the tone arm travels through an arc, it could be that shielding that should have continuity from the pickup shielding (which may be internal to the cartridge) through the tone arm and ending at the preamp input may be interrupted at the inside of the arc.
If you can see contacts at the back of the pickup (there should be a minimum of three, sometimes four) you may be able to see the shield mesh. If you have a meter, you might try carefully connecting a small clip-on probe (electronic stores will have 'mini probes') to the shield, then put the other meter lead on any bare metal of whatever amplifier receiving the signal and then move the tone arm through its arc to see if the continuity is interrupted at the inner part of the arc.
Cartridges with 4 leads are generally Left, Right, shield, and a ground. If it is so configured, then the shield and ground leads will be connected at the connector on the amplifier end.
Posted on Oct 02, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
The needle or arm is going bad, try this put a penny on the head and play, any difference? we used to do this as kids
I get an intermittent loud hum using NAD AV316 amplifier, with stereo speakers(B connection) with phono input from Dual 606 turntable. Hum increases/changes when tone arm on turntable is touched.
The hum of course is the 60 cycle line AC voltage. Make sure that the routing of the AC power plug is as distant as possible from the stereo RCA cables.
The most likely problem is the connection of the phono cartridge to the wires in the arm. These connections usually are silver plated and become oxidized creating a bad connection. Remove the cartridge and using a fine eraser polish the connections. There is a ground connection that makes the five wire connection. Be super carfull these terminals are very easy to break
The phono connections to the stereo is very low voltage subject to interference. The connection to the magnetic pickup at the tone arm is low impedance and is inductive. Any poor connection between the cartridge up to the AV316 will produce this hum. Continue to check connections and swap cables with a known good to resolve.
I have switched the left and right cables to ensure that the cable is not the problem.
Hope this helps?
Sep 26, 2016 | NAD Audio Players & Recorders
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
Zener diode and hum in guitar amp
It could be the diodes, but whatever is the cause it's before the pre-amp section. Generally a loud hum such as that with no effect by volume control, is mostly caused by the filter capacitor in the power supply. And that hum is the 50HZ mains hum getting into your system!
Feb 26, 2013 | Audio Players & Recorders
Humming sound while driving
if the noise changes if you swerve on the road it would lead towards a wheel bearing if it stays the same rotate the tires and see if the noise changes to the rear
Jun 30, 2012 | 2004 Mercury Mountaineer
Loud humming noise from right front end of 99 blazer
the noise is coming from the wheel section, it's called air splash, humming varies with speed, main causes are wheel alignment due to loose ball joint, check if your tire erodes on one side, next check your disc brake for clogged air cooled vain and disc wearing
Feb 23, 2012 | 1999 Chevrolet Blazer
I have a 1015 OMT vinyl machine that randomly develops a loud hum from time to time while playing a record. Turning off the machine for an hour makes it go away. I have ground lifted the AC power cord but...
Your problem is either in the amplifier board (I can repair these) or the cable going to the cartridge on the tone arm (I stock these). When the machine is making the humming noise, unplug the cable from the tone arm at the top left side of the amplifier...If the sound goes away, I'd suspect the cable. If the sound continues, I'd suspect the amplifier board. Please fee free to email for more assistance, tech@wurlitzer-ohio.com.
Feb 05, 2011 | Wurlitzer Jukebox 1015 One More Time...
My teac p-595 turntable has a grounding wire that is looped at one end but I don't know where the loop goes. The wire on the other end is fastened to the receiver.
The ground wire should be attached to the metal chassis or the tone arm metal assembly, the other end should be attached to the metal chassis of the amplifier. If the ground wire is not used, you will get real loud hum through the amplifier.
Nov 23, 2010 | Teac P-A688 Turntable
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
HAVE YOU GOT ANY OTHER EQUIPMENT CONNECTED IF SO DISCONNECT THEM THEN JUST USE THE AMP,DECK AND SPEAKERS AND MAKE SURE THERE IS NOTHING ELSE PLUGGED INTO THE SAME CONNECTING LINE
THEN ADD THE OTHER ITEMS ONE BY ONE
DEREK
Nov 16, 2008 | Philips gemini XL-500 II Turntable
Sony PS-LX350H Turntable Logo
143 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
