Question about Black & Decker B2300 Bread Machine
Peddals Please tell me what I can do to prevent the paddles from staying in my loaf of bread. This is a very annoying problem for I have to cut them out of the bottom.
  • Anonymous Oct 30, 2008
    I have the same problem :(
  • 3 Answers
I would suggest that you remove the paddles right after the machine has stopped mixing the dough. Hope this helps.
Posted on Nov 17, 2008
Paddles stay inside the baked loaf. Ruins the bread trying to get them out. How can I prevent this from happening?
Look up in your manual. Most have recipes, tricks and tips.
Don't have the nmanual? Specify make ans model
Or look for it yourself, use google search for terma manual, make and model
Or maybe this website might help you?
14 Proven Tips for Bread Machine Users 14 Proven Tips for Bread Machine Users Self Sufficiency
May 27, 2015 | Kitchen Appliances - Others
Paddles end up inside the loaf when done baking !!!! why do they come off!!!? very annoying.. ruins the loaf trying to get them out ......think the machine is only good for mixing ...rather bake in oven in...
This is common in all bread making machines. You can try taking the paddle out of the machine after the last kneading cycle and before final rise. (take bread pan out of machine to do this). Hank
Jan 31, 2010 | Black & Decker B2000 Bread Maker
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
I love my bread machine, model 5890, but with every loaf of bread the kneading blade stays inside the bread. The bread is also difficult to take out of the pan. This has led to scratches in the pan as...
I usually take the paddle out of the machine at the end of the kneading cycle and before the rise cycle. (Do this with the pan out of the machine..just in case). You don't want to use anything in the pan that will scratch it. Usually a few quick taps of the bread pan on the cutting board will free the bread.
Dec 05, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Cooked loaf not coming out of the tin
Sounds like the paddle is no longer non stick..
Might be worth changing it.
Feb 12, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Paddle comes off inside bread
We have had a number of bread makers and this is the way they work - the bread cooks and the paddle has to pull out somehow so it just rips a hole in the bread.
We found it better to let the machine do all the mixing etc. then my wife takes the dough out and puts most of it in a loaf pan and some in the form of buns in another pan. Works better for us & the bread is a more "normal" shape rather than the odd shape produced in the breadmaker. Also the crust isn't so tough when done our way.
Jan 25, 2009 | Sunbeam 5891 Bread Maker
Paddle stuck inside bread
I have the B2300 bread machine as well and I have encountered the same problem as you. So, I came up with the idea of removing the paddles right after the machine has stopped mixing the dough. Whenever I bake bread at home, I tend to follow the above mentioned solution and it made my life much easier.
Nov 15, 2008 | Black & Decker B2300 Bread Machine
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Black & Decker B2300 Bread Machine Logo
91 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
