Question about Refrigerators
Refrigerator repair the lever on the ice dispenser needs to be replaced. My question is,"can the average person change it or does it require professionals."? I have the replacement already but question my ability to fix.
  • Refrigerators Master
  • 19,396 Answers
The lever on the ice dispenser is not a difficult part to be replaced. It does not need soldering, working on electrical parts, or taking apart fridge main assembly.
If you want to do it yourself, you find replacement parts, and mountage diagrams here, just enter model number.
If you need to call a technician instead, you can use the phone number printed on the user manual.
Posted on Oct 02, 2008
Why is my GE Profile Refrigerator ice maker no longer dispensing ice?
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still...
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
May 29, 2011 | Maytag Refrigerators
The freezer side every 2 to 3 days the fan makes a noise and the ice begins to melt. It drips from the ice dispenser. The following day every thing is frozen again. The refrigerator stays cold.
This may sound a bit harsh but turn off the water to your icemaker for several days. What your describing sounds like the icemaker water valve is leaking water by the diaphram and is leaking into your freezer. This is a common symptom of failing ice maker water valves. I just went through this on my own personal refrigerator where ice was building up. After changing the icemaker water valve all the ice build up ceased.
So turn off the icemaker water supply for a few days.. break out the ice trays if need be and see if the ice build up stops. If it does then the ice maker water valve will need to be replaced. Fyi they run $38 to 55.00 on average and you can change it yourself. Should the need arise here is a link to a replacement water valve source:
Close up view:
Thanks for choosing FixYa.
Aug 30, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool Gold Side By Side Ice Dispenser Problems
Instead of what you think the sound is, try and see what is happening when you actuate the ice lever. open freezer door, depress the door light switch, or tape it closed. now actuate the ice dispenser lever, does the flapping door open, that which opens to allow ice from bucket into your glass? Now look at the bucket itself, do you see the gears rotating? remove the bucket from the door, and repeat, do you see the auger shaft rotating?
Either of these are a complex repair, one I would not recommend DIYers to try on their own, for they require taking the door apart, and if not done right, your door may not close properly. Normally I have no problem advising a repair, but there are some i dont, this icemaker system, and compressors.
Visit for refrigerator service or to ask general refrigerator questions.
Dec 11, 2009 | Whirlpool GS6NVEXSL Side by Side...
Dispenser does not dispense
Sep 03, 2008 | GE Profile Arctica Stainless Steel Top...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Refrigerators Logo
233 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
