I have a problem with the screen saver, some times it work some times dont, of course is on on the scree saver options, and I'll try with different metod, but is's still have the problem... :)
Click Start/Control Panel/Display and look at your screen saver options. You may have the minutes too low and you might have it set to always require a password once the screen saver kicks in.
Click Start/Control Panel/Power Options Look at your power options and settings. You may have them set too low and the system is either hibernating, sleeping, etc.
At first I thought your system was overheating and turning off but that is not the case if you are able to put in a password and log right back in and resume.
Control panel
Power options
adjust time for monitor time to sleep you can adjust 5 minutes to never the option available
same can be done for hard disk. This is necessary as even monitor is active and when hard disk goes to sleep you may end up in same situation
Alternatively you can activate screen saver by
right click on desktop, settings screen saver choose screen saver set time to activate screen saver.
When you set the screen saver there will be an option for the computer to be locked after like 15 minutes idleness. You need to disable it to keep your screen saver on at all times. It is either in your graphic properties settings about screen savers or the power options you can open with a button on the dialog box of screen saver settings or you can open the power options from control panel. If you tell me which operating system you are using I will show you the detailed steps.
The option is under Screen saver options or there is an idle time shut off selection under Power Saver options as well. When you select your screen saver there is are specific options to customize how it shows and how long before it activates. Some screen savers have more options than others.
There is a small check box in the Screen Saver area that sets this. (Control Panel, Personalization, Change Screen Saver in Win7, for example) Uncheck the box "On resume, display the logon screen" that is next to the drop down for how long until the scree
In Windows Screen saver can be managed from Display Properties window. Follow the steps given below: When using Windows XP, right click on the open space on the Desktop then click Properties to open the "Display Properties" window. In the "Display Properties" window, click on the "ScreenSaver" tab to manage it.
When using Windows Vista, right click on the open space on the Desktop then click "Personalize" to open the "Personalization" window. Next, click on the "Screen Saver" option to open the window where you can manage settings related to screen saver.
you may have screen saver active with no background selected, so when it goes to screen saver it only show blank scree. next time screen goes blank touch a key, if screen comes back, it is your screen saver, go to control panel find personalize and go to screen saver, make changes.
You need to use the Toshiba "Power Saver" console. Go to Control Panel -> TOSHIBA power saver. Click the Icon and use the console to adjust the brightness for the various power schemes. If you don't see the TOSHIBA power saver icon, go to Go to Control Panel ->Power Options and open that console. Select "TOSHIBA Power Saver" option in the "Power schemes" dialog box. If you don't have that option in the dialog box, you need to go to the Toshiba site and download the Power Saver installation file and reinstall it.
its very simple ...
just save it in phone memory...
more over go to www.nokia.com/asia so that u can see more wall paper &screen saver of ur compactabilty...
Right Click on Desktop select Properties select the Scree Saver tab Click on the Power Button which is on the right side select the power schemes In that select the power schemes options and choose "Never" for turn off monitor, turn off hard disk and system stand by click on Apply Repeat the above step for each option in "Power Schemes" then click on ok
