Question about Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each
Little gem mobility scooter brake not working properly
When you release the forward or reverse lever the scooter keeps moving for a good distance before it comes to a stop I would be grateful for any information about this problem
johnbrennan21@blueyonder.co.uk
  • Anonymous Mar 18, 2014
    The batteries are weak, would this cause the problem?
  • Drive Medical Master
  • 1,271 Answers
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Posted on Jun 14, 2009
Hi I've got a rascal mobility scooter when u push the lever to go forward or back the reversing beeper come on and it doesn't move
could be low batteries or stuck relay or the lever that lets you push it is in released position .
Feb 29, 2016 | Health & Beauty
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
I cannot start my Celebrity X mobility scooter. Drops into free wheel when I apply power lever.
After a fault has accorded with the scooter and you have reset the fault. Turn off the scooter with the key and count to 10 then switch on again. This will reset the fault in the system. If still have fault, try moving the lever in and out a few times in case the brake micro switch does not make circuit properly.
Mar 21, 2015 | Health & Beauty
My quingo plus does not move either forward or back but electrics seem ok
Hi there sorry to hear your scooters got problems, one or two things could be wrong,
1 make sure the brake lever is engaged properly this will be located at the rear end of the scooter.
2 if the above does not work you could have a problem with the brake itself.
3 does the scooter beep when you turn it on or when you engage the wigwag in the forward motion.
4 if you still cannot get it going give me a call
07950886614
Good luck
Pete
Oct 11, 2014 | Health & Beauty
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Go go traveller mobility scooter lurches forward when finger is released off forward control lever. mum has problems getting it to move forwards smoothly and slowly without it suddenly moving forwards...
That lever is attached to a pot. Pots have this nasty habit of oxidizing. You can either replace it or get some CRC QD Contact Cleaner. Wash it down trying to get as much cleaner into the pot as you can. These pots are normally not sealed find a little hole and spay it there. While your in the control head use the cleaner to clean anything you find in there. Stall having problems contact me.
May 30, 2012 | Health & Beauty
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I...
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Jun 03, 2011 | Health & Beauty
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
Small bar on tiller to make it go forward and reverse broken so no way to control start and stop. Also, free wheel is broken and scooter moves when in stop mode or key is removed. can I still use it,...
Hi. Are there other faults as well? Maybe you should get another quote from a different technician, or ask him if he has any second hand parts available.
If you use it, and you cant control it, you end up down a bank or under a bus.
What brand and model is it?
Sometimes the brake disc in the brake unit splits and allows the machine roll on. Sometimes the brake lever has had a bump, and just needs to be pushed back into place properly.
Try contacting the authorised service people for this scooter, and get some prices from them. Good luck. Neil.
May 13, 2010 | Electric Mobility Mobility Electric Power...
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
479 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
