Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Printer thinks its out of paper
My XD125f has been a workhorse with limited problems. Today, however I tried to print and nothing came out. After about 10 minutes I received an error message on my computer that said the printer is out of paper. The printer had about 30 sheets, but I filled it up and still received the no paper error.
The printer must not be detecting paper -- is there a paper level sensor I can check? Other ideas?
  • aahsome Oct 02, 2008
    Thanks, but the problem is not with the document feeder, but the paper tray. Any ideas there?
  • 70 Answers
  1. Open the Document Feeder by placing your fingers under the opening where you feed paper, and lifting upwards.
  2. Locate the black Paper Sensor (the black plastic switch that hangs down).
  3. Make sure the Paper Sensor is not pressed in. It should move up and down freely.
  4. If the Paper Sensor is stuck in the up position, try to gently pull the Paper Sensor back down.
  5. Turn the power off by pressing the Power Switch to the [ O ] position.
  6. Turn the power back on by pressing the Power Switch to the [ | ] position.
  7. Try to make a copy using the Document Feeder.
  • If the Paper Sensor is broken off or pushed in, you will need service on your WorkCentre.
  • If the Paper Sensor is not broken off or pushed in, the Paper Sensor not the cause of the problem
Posted on Oct 02, 2008
Have a jam error. paper folds in front of print roll
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Mar 31, 2011 | Xerox WorkCentre XD125F All-In-One Laser...
My E210 Laser printer makes a "clacking" sound. I think it may be the roller that feeds the paper. It happened after a paper jam when the paper got too low. Cannot print. Tried taking out the...
Look inside and check that there is n't any paper stuck in the rollers.
Take a very damp cloth and dab it with dish washing detergent. Clean all the rollers you see.
There is a seperator pad on the paper tray , clean it also.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 08, 2009 | Lexmark E210 Laser Printer
Workcentre XD125F
Waste ink reservoir is probably full. Needs to be emptied.
Hope this helps. Bud
Jan 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F 'P' appears when I try to print...
This printer is very dumb, you have to tell it from which tray to feed. change on the operating panel or in printer properties.
Jan 25, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Paper in all trays, but won't print
try putting paper in the bypass unit on the right end of the copier by pulling the shelf down.
Dec 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
Hp 7260 will not pick up paper
Yea, I have the same problem. The only answer I can think of is to never buy another HP printer. I've had nothing but trouble with this piece of garbage!
May 13, 2008 | HP PhotoSmart 7260 InkJet Printer
Printing to Xerox XD125F
That will print via Parallel port , Just have to go to www.xerox.com
go to drivers and downloads and then type in xd125, dowoload the driver and use the autosetup.
It is easy to set up.
Apr 12, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
552 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
